Originally posted by martinjs
Awful running
I've actually got a metal dizzy gear from the guy from ebay - he lives around in West London and I met him once in the GSF car park of all places. I've not done anything with it yet, it's still sitting in my glove box.
This all sounds like a bloody nightmare though.Ex S2 owner, now running around in an A4 Avant quattro...
Its not as bad as it sounds Dan. Is the anti tamper plate still there at the base of your dizzy? You should be ok using Johns method of removing ISV etc. I only remove the manifold because mines been apart loads of times so dont have any problems getting access to bolts etcComment
I'm afraid I don't know what the anti-tamper plate would look like to know if it's there or not?
If the rotor arm is bonded on, do replacements re-mount ok?
How does the metal gear fit inside the distributor?
How much am I looking at for new rotor arm, dizzy cap AND 7A HT leads do you think?Ex S2 owner, now running around in an A4 Avant quattro...
You could go for Magnecor 7mm leads. The are black/grey and I'm sure they do them for the 3B, they do them for the RR at about £120ish (with a 10 Year guarantee).
BTW, anyone know what symptoms does a nacked dizzy gear gives?.
I have noticed a kind of slight 'rattle' around the dizzy area on my engine when I was raising the revs slightly by moving the throttle cam by hand. Is it about to fail?! (car's done 86K miles).
And is a Bronze replacement a good idea?, not sure about bronze bits eventually floating around the engine!
There is a u clamp at the base of the dizzy body which clamps it into the head, from the factory there was a plate rivited to it to stop people being able to get at the nut to alter the timing i guess. Here is a pic of my spare head.Originally posted by dan_bI'm afraid I don't know what the anti-tamper plate would look like to know if it's there or not?
If you can see the nut on yours you will be ok.
The rotor arm will be a tightish fit like on any other car but i would glue the new one on too.
@Pete, they do start to rattle, is it still the original plastic gear?, You dont want plastic bits floating around your engine either, thats happened to lots of people
HTH
MartinAttached FilesComment
Thanks to Spink for popping round today with VAGCOM. Only having a 3B, we weren't given the full suite of diagnostic and parameter logging facilities that you ABY boyz enjoy, but it did throw up a few things!
Firstly - I definitely have an MTM ECU. That's nice!
The only error message it produced was this:
Oxygen Sensor G39: No signal - intermittent.
Looks like I need a new lambda? How much, where from, and what's it like to fit? Can a spanner-muppet like me manage a job like that?
I'll do the lambda first before embarking on the dizzie path, although I'm sure that's probably not in the best of health given that it's a 15 year old car with 125,000 on the clock in the damp English weather!Ex S2 owner, now running around in an A4 Avant quattro...
Im sure someone will correct me if I am wrong but I think that you can buy a Lamda from any motor spares place(doesnt have to be an Audi part) reckon the s2 uses a 3 wire and they cost about £60
Never changed one but I reckon its an easy job(Im a spanner-muppt also)Jon
91 3b S2
Now SoldComment
It goes in the downpipe, you can see it in the pipe opposite-ish the airbox.
Just did mine recently. Not hard to do but there's not much spanner weilding room, easier if you have the special lambda spanner/tool but it can be done with a combi.
If your car's never had a replacement it definately will need one by now. They usually need a new one every 60K.
try VAGParts for a Bosch one.
@Martin, I reckon its still on the placcy gear, another item on the to-do (now!) list!
You cant actually see it in this picture but if you follow the arrow you will find it.
It is attached to the exhaust with a wire coming out of it.
Not the best description but hope it helps,Attached FilesJon
91 3b S2
Now SoldComment
