Ok A problem won't start
  • Sweeper
    • 1317
    • Country: Latvia
    Ok,engine is now completed but won't start. It started for one time but now no use.
    Problem :
    Trying to start it but no electricity on sparks, electricity goes to distributor(coil pack or whatever it called on 3b) , but nowhere from there !
    Any ideas ?
    Vadim.
    New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
  • Jonas_R
    • 3780
    • Country: Denmark
    Well perhaps a bad distibuter, mine die the other day but you might be able to start the car anyways.
    Simple put the car in gear, well 3rd og 4th and then push the car a bit back and forward. Then try to see if you can start it, worked for me a couple of times before i got it to the garage.
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
      Check the timing marks syill all line up?
        I think then I'd be checking all the sensors and their plugs, hall sensor in distributor and flywheel sensors. ECU connection.
        • porkkis
          • 1994
          1) is the dizzy turning -> gear ok
          2) is the timing right both engine timing and dizzy alignment
          3) hall sender
          4) flywheel 62 degree peg and its sensor
          That's the most obvious ones.
          • Sweeper
            • 1317
            • Country: Latvia
            Where is hall sender located in 3b ? same place as in aby ? Behind Camwheel ?
            Will be checking sensors on monday.
            Checked dizzy (fine) , checked flywheel pin fine
            And is there a way to check if hall sensor/flywheel sensor is faulty without buying one ?
            Vadim.
            • spink
              • 4382
              The 3b hall sender is in the dizzy, i had one pack in last year.
              • Sweeper
                • 1317
                • Country: Latvia
                3) hall sender
                Porskis , ok BAD NEWS.
                1) dizzy turning , I have a metal gear
                2) How can I check that ? Is there any tutorial on correct timing , maybe I missed something , FOund a dizzy alignment , but what about engine timing ?
                3) hall sender - check all working
                4) flywheel peg is on the place and sensor is fine
                Could this be due to the High lift cams installed or Adjustable Cam gear ?
                I'm gonna check the car with vag com in few days , can't think of anything now .
                Vadim.
                  Sweeper just had this on the ur forum today, same story, look for zero in timing windo in bell housing then check marks in dizzy.
                  • Sweeper
                    • 1317
                    • Country: Latvia
                    Newsh: Thanks.
                    Well today she run , happy happy me. THe problem was in the new adjustable cam gear, dunno why but it didn't allow to start the engine :/. Put old one and now everything is fine. Guess timing on the gear was set wrong(if such thing exists).
                    Now will put everything in place , lot of work for a weekends I guess . Hehehe :evil:
                    Vadim.
                    • robo
                      • Aug 2004
                      • 2086
                      • Home: Poland Current: England
                      Originally posted by Sweeper
                      Newsh: Thanks.
                      OOOOO Vadim will I have the same problem with mine when I try to start it in saturday????????????
                      sigpic_________
                      Rob
                      • Sweeper
                        • 1317
                        • Country: Latvia
                        Heh , don't know . Give it to a proper mechanic , it should work fine.
                        It's just i removed it for a while , till the engine will be fully built and run fine , than it will be put back. I guess it's becouse it had different, non standart option in the first place.
                        Vadim.
                        • Sweeper
                          • 1317
                          • Country: Latvia
                          Robo: All fine , installed adj cam gear. Finnaly discovered the problem , it was ECU WIRING. Must have push it while was removing alarm.
                          Now another small problem , I don't get Oil Pressure Reading on the AUX dials. What can be the problem ??? Sensor ? Where is it located ?
                          P.S. Car sounds soooo sweet (with even exhaust removed) , hehehe , she gonna be on the road sooooonnn. All left is to install radiator , clima and new intercooler.
                          Vadim.
