Originally I was planning to convert Project Mayhem (a US spec 1990 Coupe) to a B4 hood, but now, for some undisclosed reasons (see picture below), I'm wondering about a B3 hood.
Can run a B3 hood with a B4 core support and RS2 headlights? Obviously I would need to most likely need to run hood pins, B3 under headlight trim (across the whole bottom), but what grille (<~ seems to a difficultly).
It's oryginally B3 with B3 hood and B3 core/centre section. All You need is to remove mount points for the under lamp trim.
