Recommend me a TIG
  • Zoig
    • Sep 2008
    • 555
    Originally posted by caterpillar
    http://www.ebay.com/itm/NEW-TIG-Arc-...-/171293808116 many use this, and are happy with this....
    That one looks really similiar to the one i listed in my search, only plasma is missing (dont really care about that): http://www.ebay.co.uk/itm/AC-DC-TIG-...item20a9746c72
    So could it be something good small DIY guy who is still learning. Provided the machine works more or less like it should, the biggest obstacle would be the guy behind this machine
    • AndyP
      • 6049
      I bought a cheap 160A DC set to learn on then after a couple of years I wanted to upgrade to an AC/DC set. I was going to get a chinese one like the the one you linked, but I decided to save up and get the one I really wanted, which was this
      The TIG 201 AC/DC 200Amp Inverter TIG Welder features HF microstart, AC squarewave adjustment to 250hz, pulse welding, slope up/down, LED display and a high 60% duty cycle at 200 amps. Includes FREE TIG torch, earth, MMA lead, regulator, R-Tech Pro remote foot pedal worth £142 and a 3 year warranty!
      Although, this one looks like great value
      http://www.ebay.co.uk/itm/Welding-al...p2047675.l2557
      • DJones
        • Jun 2005
        • 2020
        Bit of an old thread but finally replaced my Tig with an R-Tech 210 amp AC/DC (digital) machine. Went the whole hog, foot pedal, selection of tungstens, gas lenses and a 9 & 26 torch.
        Great bit of kit and I've found it so easy to use...
        Darren
        • SteveH
          • 4460
          My R-Tech Tig is still going stong after 3 years of abuse. Highly recommended bit of kit as a lot of the cheaper rigs can fail pretty quickly.
          91 Modded 3B
          14 A6 Avant Black Edition
          • SteveH
            • 4460
            I'm after a replacement torch for my TIG setup. I find the torch supplied with my unit a bit large and the hose and sheath isn't particularly flexible. Has anyone any suggestions for a smaller, flexible head (WP17) torch with a really light weight hose? I can mod the connections if required to connect to my R-Tech plant. There are loads on e-Bay, but most are unbranded and probably poor quality. Any suggestions, air cooled?
            91 Modded 3B
            • AndyP
              • 6049
              You need a CK. I have this one:-
              This is the 150a version but they do a 200a too. It's so light and flexible, you hardly know you're holding it, especially compared to the std R-Tech torch. You'll need an adaptor, but ring Rapid and tell them what set you have and they'll hook you up.
              • SteveH
                • 4460
                Cheers Andy
                91 Modded 3B
                • hiloran
                  • Mar 2010
                  • 121
                  I replaced my Esab Caddy Tig 2200i ac/dc to Everlast 255EXT (3 -phase model) with pedal and I´m super happy. Everlast have much more amps to heat up aluminium at the beginning. Pedal is also easy to decrease amps once the puddle starts going.
                  • prj
                    • Mar 2010
                    • 6308
                    I have been professionally using a Kemppi Mastertig MLS2300 with the extended arm. Light, portable, fairly high current capacity, but still a 230V socket and can weld both alu/stainless.
                    Have had it for close to 4 years now and it is used daily at the workshop, no issues.
                    Probably a bit out of budget for just using it for DIY in your spare time though.
