As you may have seen from my project thread I'm fitting water / methanol injection to my car. I've decided to fit the pump and tank in the boot to try and minimise the amount of weight I'm adding to the front end.
The pump is now located on a bracket I made
I've decided to make a stainless steel tank to fit in the compartment in the boot floor
Here are all the piece parts I had cut from 2mm stainless steel
First pieces aligned and tacked
Baffles welded in place
This is the outlet supplied with the Devils Own kit and the filler neck I'll weld into place
I'm going to sandwich a piece of plexiglass in here so I can see how much fluid is in the tank
Lid tacked in place
I'm going to try and get all the welding done this weekend and give it a lick of paint.
Lid tacked in place
