Water injection tank
  • AndyP
    • 6049
    As you may have seen from my project thread I'm fitting water / methanol injection to my car. I've decided to fit the pump and tank in the boot to try and minimise the amount of weight I'm adding to the front end.
    The pump is now located on a bracket I made
    I've decided to make a stainless steel tank to fit in the compartment in the boot floor
    Here are all the piece parts I had cut from 2mm stainless steel
    First pieces aligned and tacked
    Baffles welded in place
    This is the outlet supplied with the Devils Own kit and the filler neck I'll weld into place
    I'm going to sandwich a piece of plexiglass in here so I can see how much fluid is in the tank
    Lid tacked in place
    I'm going to try and get all the welding done this weekend and give it a lick of paint.
  • K Simmonds
    • Dec 2007
    • 7632
    Very nice work, that tank will hold a decent capacity, any idea how much? Must be Three L +.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • AndyP
      • 6049
      Approx 12l according to my calcs.
      • andy10v
        • 5996
        That is cool!
        Are you going to fit mounting tabs to the fuel tank bolts?
        Sold ABY-stock
        • AndyP
          • 6049
          Originally posted by andy10v
          That is cool!
          Yes, I'll weld those on once I can get it into position in the boot.
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            Andy could you do one for me?
            very nice work there¡¡
            • 20Vcqdriver
              • 829
              Thats a bit OTT, is it an optical illusion as it looks like a capacity more like 20 litres. I just used the present washer bottle for mine and top it up every couple of months.... Or are you intending to only fill it up once a year
              1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
              • s2_wot
                • Aug 2006
                • 2178
                Fantastic work there Andy
                Shane
                  Originally posted by 20Vcqdriver
                  Thats a bit OTT
                  There is no such thing!
                    • 12431
                    Yeah I use the washer bottle on mine currently, id be interested to know what mixtures people use in there bottles though
                    • Thuppu
                      • 4115
                      Nice custom tank. Great size, you don't have to fill it every day. How is the weight?
                      • DJones
                        • Jun 2005
                        • 2020
                        Good work Andy.....
                        I only use circa 10-15% (screen wash) in line 5's dont seem to like a lot more than that, oh... from a .5mm jet...
                        Darren.
                        • Thuppu
                          • 4115
                          Depends on if it's mapped to get full benefit of the water injection? I would go with 50/50 water meth.
                          • DJones
                            • Jun 2005
                            • 2020
                            I agree, but i didnt want to map mine for full out 50/50 more to give it some top end protection from detonation..
                            Full out mapping for it would leave me nervous of a blocked jet or other breakdown in supply. My preference is better cooling by physical means, inter-coolers etc and as i say a little top end protection from the water..
                            Darren.
                            • Thuppu
                              • 4115
                              Yea, you need to have a quite secure fail safe system. http://www.s2forum.com/forum/showthr...t=49425&page=4
