I've fitted an ABY battery box under the rear seat, battery installed and working fine, however I have a question regarding the fuel line from the tank to the filter. What have other people done here, made their own, modified what's there or purchased something?
ATM it's plumbed in using the 3B line heated and rerouted, but it's about 2"'s too short to be satisfactory.
I thought it would just be a case of fitting the ABY fuel line but unfortunately I may have got that wrong. I have an ABY line and it's no use as far as I can see unless I turn the filter around and route it around the other side of the box which would mean I'd then have to cut and alter the line from the filter to the front of the car which I really don't want to do. I'm not actually 100% sure TPS have supplied the correct part as I can't see anyway of fitting it tidily and it looks very similar to the 3B one as well as being the same length.
