I agree with the above comment. Get some self-adhesive foam and repair the foam on the flaps in the heater box.Did mine whilst we did the matrix and it makes for a stronger air current, especially for de-misting the windscreen.
Heater matrix
You need some of this
SELF ADHESIVE NEOPRENE SPONGE FOAM SHEET 8"x5" 1mm 1.5mm 2mm 3mm 5mm 10mm 20mm | eBayNothelle S2 Avant
Originally posted by Bowie69 View PostThere really wasn't anything to match with on my flaps...
You can see the outline where it was and make a card template. I think the original was quite thin, maybe 2mm on mine or less.Nothelle S2 Avant
I took the flaps out, cleaned off old dregs of foam and adhesive and stuck the new stuff on both sides so it ends up about 4mm thick then trim excess off round the edges to tidy up. Most of the old was gone though, blown out of the air vents over a period of time.
