Climate into RHD avant
This is a sticky topic.
  • rj scotty
    • May 2006
    • 2195
    #136
    The solution for the cabin temp sensor:
    In my case there was some sort of warning light on the dash that was to do with the tow bar wiring. I removed the warning light and used the redundant hole. Ill find a some sort of grill for this in time.
    just the final bits to sort out the weekend and she be back on the road.
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • rj scotty
      • May 2006
      • 2195
      #137
      Complete
      Many thanks to everybody who helped along the way !
      Got loads of pictures and tips if anybody else is going to have a go.
      • Nuvo
        • Nov 2003
        • 3826
        #138
        Well done. Did you source a 1996 CCU for vac controlled recirc in the end then?
        Did you figure out how to code the CCU for RHD 5 cyl application or did you leave it as is?
          Originally posted by rj scotty
          Complete
          Gimme the pics, and i'll be on the phone to you to pay a visit to have a look
          • rj scotty
            • May 2006
            • 2195
            #140
            1996 ccu with 1999 screen. Left coding alone as my vagcom won't talk to ccu's.
            @jamo. I rekon if you had all the parts required this could be done in 2 days.
            cheers
            rich
            • crysty7
              • Mar 2013
              • 13
              • Country: Romania
              #141
              Please seed...your experience (part number component and some final schematics)
                Its really easy if you are LHD. Find a donor car and take what you need
                • crysty7
                  • Mar 2013
                  • 13
                  • Country: Romania
                  #143
                  my car is Audi 80 B4 1994 Competition with manual A/C .
                  Audi A4 B5 1995-1996 component is best solution for climatronic swap ?
                  I found on local scrap yard one Audi A4 B5 1999 with climatronic ,but remain same problem about HVAC flap recirculation for mine .
                  Possible combination : 1999 A/C climate housting + 1995-1996 climate control 8D0820043H + HVAC from existent Adi 80 B4 ?
                  • johne
                    • Apr 2007
                    • 1406
                    That's a good combination as the 8D0820043H can control the recirc flap on your HVAC from the B4.
                    John
