Hi all I have embarked on the mission of installing the later B5 digital climate into my 3B coupe.
I have read through all the threads done by ShadowofBob, Johne, rjscotty and S2Central.net.
And they are going to help out no end!!!
I will document what I have done with my install to help others as there has not been any input for over 2 years on this now, and I am sure I am going to need help
I have managed I believe to source most of the parts required for the install however from another forum member who has had the loom stripped out and labeled so should give me a pretty good head start.
I have a spare centre console so have been adapting this so I can just swap it all over in one go fingers crossed.
First of all I have trimmed out the plastic to allow the new climate frame to slot inside the original console.
I will update with part numbers later.
I then marked with marker pen from inside where I needed to drill the holes to rivet the new frame into position, this was then drilled and riveted
Now the climate head unit can be slotted into position
The finisher trim requires two plastic retaining clips which I have ordered today. Part No. :8D0837073
I will picture them once they land
This will then look like this
The rest of the rats nest then looks like this....
Along this process I will be wiring in my solar sunroof to perform 2 functions. 1 to charge the battery with a trickle charge and the other to run the fans via the climate.
This is the control panel
I am missing 2 of the internal cabin temp sensors and the photo light sensor which I have ordered today and will list the part numbers when they land.
However I hope to use the cabin temp sensor that comes in the solar control panel
That's as far as I have got at the moment, but will update as I go.
What I wanted to know first of all is did anyone actually manage to have a permanent solution for the fresh air flap?
