why not just use the S2 pressure switches?
Having said that I noticed the low pressure switch for the digi climate is different to the normal AC one - I think it switches a higher current as the wiring to it is thicker.
Rich & John - did you just use the normal AC low pressure switch on your setup?
Brian, I think I might have 2 of those original clips for the dash trim surround
The screws in ETKA for it are the wrong size I also had to have a dig through the nut & bolt box to find something suitable
