Audi S2 RHD Digital Climate
  • rj scotty
    • May 2006
    • 2195
    #31
    I've got my head around the low and high pressure switches for this system now
    Slightly different to the b4/early b5 system
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • rj scotty
      • May 2006
      • 2195
      #32
      On the b4/early b5 system the head unit monitors both high and low pressure switches.
      On this 1999 A4/passat system the high and low pressure switch's are in what looks like a combined unit and a single signal is sent to the head unit via terminal C2.
      This could be achieved on the s2 with a simple relay, using the 2 pressure switches to emulate the function of the combined pressure switch in the later system.
      This was the other obstacle I had to over come that pushed me into getting the H suffix controller, I reckon I have cracked it now though
      • Tonks4x4
        • Nov 2005
        • 3062
        Cool, thanks for that. If the passat has a combined unit I wonder if that could be used and just screw it into where the sender is in the S2.
        Also there is some wiring labeled as cabin temp motor drive....
        What does this motor drive look like?
        Tonks4x4 - The Land Rover Specialist
        Audi Nut!!!
        • rj scotty
          • May 2006
          • 2195
          #34
          This revelation has implications for the labels I put on that loom. The numbers/letters are all correct A1, C2, D3 etc but if there is any other notes (I can't remember if I made any or not) I would ignore them
          • rj scotty
            • May 2006
            • 2195
            #35
            The motor is a tiny little fan that draws air over a temp sensor. As far as I can remember it's not in with that kit and will need sourcing. That labelling is correct
            • rj scotty
              • May 2006
              • 2195
              #36
              I've not seen this combine pressure switch but on the S2 the high pressure switch's (there are 2) are at the front of the car on the condenser and the low pressure switch is on the pipe work going to the evaporator. John may be able to advise whether the combined unit can be substituted.
              • Tonks4x4
                • Nov 2005
                • 3062
                Yes there were no sensors or motors with this kit and I was of the understanding.
                "Everything needed for installing climate"
                Meant that I would at least get the sensors required
                Anyway I have ordered the sunlight sensor and 2 x cabin temp sensors I have to now sort this sensor motor
                Audi Nut!!!
                • rj scotty
                  • May 2006
                  • 2195
                  #38
                  4A0 820 545 is the fan
                  8D0 820 547 is the hose to join the fan to the temp sensor
                  Model a4 1995 mg8 sg19 ilustration 819-45 in etka
                  • rj scotty
                    • May 2006
                    • 2195
                    #39
                    fan looks expensive in my version etka, get down the breakers yard
                    • rj scotty
                      • May 2006
                      • 2195
                      #40
                      ebay has it's uses
                      http://www.ebay.co.uk/itm/Audi-A4-Ce...item3f20f1d69f
                      • Tonks4x4
                        • Nov 2005
                        • 3062
                        Thanks for the part no. I found one on eBay with the pipe and a length of wiring.... £15 delivered
                        Audi Nut!!!
                        • rj scotty
                          • May 2006
                          • 2195
                          #42
                          nearly there then
                          I'll keep working on this pressure switch idea I'm intrigued now!
                          • rj scotty
                            • May 2006
                            • 2195
                            #43
                            Reading through all my old notes, it's amazing how it all comes flooding back
                            • Tonks4x4
                              • Nov 2005
                              • 3062
                              I am sure I will manage to get my head round it once the dash is out and I can bare my wiring loom with everything and the diagrams in front of me.
                              I appreciate your help along the way though....
                              Audi Nut!!!
                              • rj scotty
                                • May 2006
                                • 2195
                                #45
                                This combined pressure switch may be a red herring, just checked up to model year 2001 and the parts diagram shows separate pressure switch's. It may have been combined on the wiring diagram purely for clarity
