This is 6mm thick
I had to make the RS2 logo 24mm high to be able to machine it.
Porsche letters are 16mm high
I'll take more pictures when I get home.
D
What were you thinking for the Alu version? Welding?
This is a mineral/acrylic composite, used for expensive kitchen work surfaces and ...signs. It is very hard, will shatter if smacked with a hammer.
This will char if exposed to severe heat (I think) and is not weld-able.
I could route some recessed holes in the front if you wanted to bolt/screw it on.
Did someone not post on this thread saying they had one "stuck on". That was made me think of using this material.
There must be a Scotch "Space" Tape for holding tiles onto the outside of the shuttle.
I've got some gaffa!
Dane
Reason: didn't answer the question!
hmmm
in that case the rough surface of the inlet manifold would have to be very lean and polished,for any type of glue to keep that in.
preferably i would like it to be in somekind of metal shape and quite thin as well,in order to be able to weld it on.
that is why i was thinking of the letters punched out,rather than carved in.That way the thickness of the letters can be as thick as the sheet metal that is used for it.
I can route aluminium, I just don't like doing it on the vacuum bed. I nomally use a 3mm tool so large lettering isn't so much of a problem. The detail in the RS2 logo is not something I have done in alloy. I broke a 0.7mm tool messing with the corian one, ÂŁ12!
Will give the alloy a go, "Porsche" or "S2forum" when I get time to mess. :mischeif:
The photos do not do the real thing justice!!
Nobody fancy S2/RS2 coasters?
Was thinking about being able to do air vent inserts for Ooomph Gauges in corian
Dane
Designs need to be raised and lowered areas.
I can do 3D but it's a slow and expensive option.
Designs need to have lines 2mm for best effect and speed of production, especially for short runs or lunch-time jobs.
D
Here is one that I laid out to machine my manifold. It could also be machined into an aluminum plate to be welded or bonded to the manifold. I also have a 'powered by Audi Sport' version with the audisport parallelogram logo, but I like the original...i can supply the cad files if anyone is interested. the 'powered by' font style is close to the original, but not exact. if anyone has a better font style match, let me know and i'll update the design. also, the corner radii are adjusted for .031 end mill in 'powered by' text and .125 end mill on 'porsche' logo...
