I will try and find it - I think Mark H might have posted a link to it on here a couple of months ago.
AAN Inlet Manifold on ABY
Thank's Doug. I have send Mark H a PM.AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
http://www.sls.wau.nl/fstolp/magazin...ver/500bhp.htm
This is the only thing I could find but it only says it has been moved, not giving the lean no1 cylinder reason.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
Here is a Suggestion,why didnt you guys make up a plate for a VR6 TB or Mustang TB since your going through all that trouble anyway?
Also found this interesting picture and thought you guys might like.Its a RS2(same as 3B without the Porsche emblem) that they have simple cut and flipped around.
I know you guys will like....
p.s. has anyone heard from Corey?I have been trying to get a hold of him.
Thanks...Attached Files
Originally posted by Doug_RS2http://www.sls.wau.nl/fstolp/magazin...ver/500bhp.htm
On other hand if there is litle less air and the same amout of fuel there is no reason to worry. AFR will go down a litle bit, EGT down a litle bit ..
and now i'm geting confused. The only explonation is that with motec they have have modyed it a bit ??AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
Wizard: Everything is great and good looking but .... where is the radiator ????
Ah , stop I see it , it's on the apace of aux radiator :/.
No air conditioner then ...Vadim.
In the backAKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
Albert: The one showned previously is 2.5L engine , the one on your picture is 2.2L . So I guess they are different , so different manifold.Vadim.
The CC wont mater ... the head is "the same". the 2.2T version has 600HP and 2.5L has 500HP ... so it would mater more in 2.2T versionAKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
Albert - the silver shortened UrQ one was at the GTI International meeting a couple of months ago - It had the throttle body moved to the front - or so I was told - Does anyone have pictures to confirm this?
You are right, the front cylinder one might be a bit richer - not leaner!S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
Originally posted by Doug_RS2Thanks Albert. It is from Dialynx - A UK Audi specialist - there is an article on it somewhere. I think Mihnea told me about this problem as well - It would be easy to test if you had 5 temperature probes, one in each exhaust runner - you could see if no1 was running lean/hotter.
Then again, the RS2 EM is supposed to help a hot condition in the end cylinders, which makes me think of lean not rich. So, I don't know but I'm curious.Kenneth
1990 Coupe quattro
1991 200q20v x 2
1985 4ksq 20vt project
1986 Coupe GT 10vt project
2006 Honda Ridgeline
1998 Honda VFR800FI
thats the second car ive seen with the rs2 manifold chopped about like that, looks very good, 2 stock dv's venting to atmosphere though??
the 3b manifold is different to the ADU btw, slightly smaller volume, ADU and ABY are the same though
martin
Originally posted by martinjsthats the second car ive seen with the rs2 manifold chopped about like that, looks very good, 2 stock dv's venting to atmosphere though??
martin
I was told ADU and 3B were the same (internal volume wise).I am Inexperienced in this field so i guess your probably right.
Progress so far
Been working on it most of yesterday and today, and its almost done. I've welded the plate onto the side and the lugs for the throttle cable and the dipstick tube have been welded onto that.
Just a few more things to do to it and it should be done.
I hope it all works OK when it goes on the engine, its been a lot of work, the welds seem to be good and strong, but it'll have to be able to take up to 2 bar + internal pressure and engine vibration........I'll have to keep an eye on it for a while.
Cheers,
Mark.Attached FilesMark - Modded
