I've just removed the WG and turbo studs from my ABY manifold to fit to the Wagner EM.
On the turbo studs, there is a small amount of thread that has lifted a little, should I run a die down it to clean it up or just screw them back in? They were quite stiff to get out (I used the 2 nuts locked on each other method).
Also when fitting do people use copper grease or fit them dry?
These are made of some kind of serious metal, I'm wondering if a die will even work on it..
