From memory there is one small bolt at the front of the seat, 8 or 10mm in size, then you remove the plastic trims from the guide rails and slide the seat fully back out of the rails. The seat rails are covered in grease so put an old rag down first so you dont make a mess of your carpet. If you have heated seats dont forget to disconnect them first.
Mine only leaked when parked up for a few weeks, i found it using a garden hose directed at the a-pillar. It was strange then it suddenly started for no reason, changed the door seal and its been fine ever since.
any probs just ask
