Originally posted by Rusty
View Post
To get it out cleanly you would need to remove all the heater gubbins and steering column too.
Another thing I discovered tonight is that my windscreen has been replaced before my time. It is definitely not leaking into the inside of the A-pillar as I removed that for a peek - and discovered the monkey what done it before broke all of the locating clips on both internal trims - they came out waay too easily but such is life.
Need to get brave enough later in the week to tackle the door seal... Hoping to find the root of the leak on the outside edge of the A-pillar - where it then finds it way past the tired old door deal.
I also couldn't see an obvious place to secure the cruise control module on the dashboard.
Spent some time documenting a heap of connectors and other boring trivia, but it will be important to someday one day I suppose.
