Petrol leak
  • AndyP
    • 6049
    I've now changed the sender unit, the seal and the locking ring and it still leaks FFS
    • benntenn67
      • Jun 2009
      • 859
      I might be barking up the wrong tree but, have you tried lube on the seal ? like you would with an oil filter say - help the seal to seat
      Audi S2 Coupe 1995
      VW Passat GL5 (hatch) 1986
      Carrera Subway 8
      • denniselbows
        • 740
        top of the fuel tank must be distorted then or the tank is being pressureised
        never set your expectations to high that way you are never disapointed
        • AndyP
          • 6049
          You were not barking up the wrong tree, I think this was the key to sealing it. I was putting the seal on dry and I think it was getting dragged into the tank when I pushed the sender unit into place. I put a smear of grease on it and it seems to have sealed it, so thanks
            Excellent!
