As title, due to exhaust noise I could do with an upgrade. What size are the stock ones. What can be made fit that doesn't look max power. Cheers des
urs4 front speaker upgrades
The oem frontspeakers are non-standard size, somehting between 5" and 5,25" (5,14" etc.). Here is a pic of a 4" DLS vs OEM. I did a downgrade from 5,14 to 4". Well, they sound better after all, luckily.
I made plug and play adapters for the 4" speakers to fit the OEM door enclosure.
Was the oe speaker nokia or was a bose?worth changing Bose to dls?I did a dls swap in my 100 c4 but removing the plastic inside the dor and insulating dor and panel with special acustic insulator(how do you call it?).But bose worth to be changed with dls without removing the plastic acustic box and using the entire dor for acustics?
