"OEM" look headunit
Blaupunkt looks great. Somebody buy one when it's out so we can see how it looks fitted.1995 Audi S2 AvantComment
My bugdet Becker fitted today. Sounds nice and has line in/out & sub out (with ISO connector).Comment
There is roughly 1500 reasons why this is way too expensive. Still, 1Din and android auto is something that i'm also looking for my UrS6, if only it was cheaper.
The car has long gone (sold to Athens somewhere) but I did find some pictures that may be relevant to the topic. The headunit is a Audi Concert off an Audi TT MK1 and because it had a Bose sound system (which means that it was hooked to an amplifier) the speaker exits didn't work so I connected and external amplifier to line out. Later I added a USB port (seen on some photos next to the headlight beam adjuster). For some reason it won't let me upload certain photos so these are the only ones I could share.You do not have permission to view this gallery.
This gallery has 3 photos.Comment
Thanks David. I got the idea from a Audi Cabriolet brochure. It had an Audi Gamma (if I remember well) with wide fascia and it looked fantastic! I went to great lengths to achieve this look so I was very pleased with it. I had to buy the Audi Cabriolet centre console to fit wide Audi OEM headunits and it was very rare to find. Being under the impression that all wide Audi headunits had the same dimensions I bought this Audi Concert unit (which was also rare and expensive) only to find out that it was too wide (220mm in fact instead of 217mm for Audi Gamma). I've sanded these extra milimeters off and it fitted just fine but then, as I wrote above, I discovered the speaker outputs were disabled and I had to connect it to a newer Audi in order for them to be switched on via a VAG-COM tool. I wasn't able to do that but instead I bought a mini amplifier (Pioneer) that I'd hidden inside the dash (over the glove compartment) as I didn't want any amplifiers spoiling the cabin's factory look. Replaced the speakers with better ones and... I had a pretty decent sounding car stereo!Comment
It’s mine Rob! And yes it’s going in the Ur
I still have my original Toronto and the radio works but I’ll put it away safe and this one will be lovely. I just made up another motorised aerial after the last one got stuck in down mode and melted itself.Comment
Looks very nice
Urs6 plus project goneComment
