New head unit
No it will flatten the battery as the Bluetooth finder will be in all the time, you need to take the switched feed by tapping into the thin red wire on the back of the ignition switch as described earlier in the thread.
BTDT with the same radio and had the flat battery to prove it.Comment
Saving battery:
Example of wiring in my 80 B3:
Power wires from battery:
sigpicComment
Thanks a lot guys,
Windscreen in this morning and then I'll crack on with the stereo/sub.
Found a few comment on other forums that mention "any black cable" under the driver's side dash will give me a switched live?Cheers,
Grant
S2 Coupe ABY '94Comment
But then the stereo will go off when you switch off the ignition, the thin red wire will stay on with the ignition off untill the key is removed. So you can run the stereo parked up. Useful?Comment
Yes, Optima Yellow Top.
Now i'm building the audio system in my coupe and it's plan:
May be i start my own the thread about it... may be it be usefull for someone.sigpicComment
Yeah, I'll just man up and wire it from the rear of the ign tomorrow. Had a quick peak today and it looks like there are a couple of red wires (can't be certain but the gauges all look roughly the same
Cheers,
Grant
So that's the stereo and sub in now, ran from the thin red at the rear of the ignition (thanks Newsh)!
Not the tidiest of jobs, I used terminal blocks instead of soldering; but personally I have more faith in terminal blocks than soldering joints. Plus no-one will see it behind the headunit or under the dash.
Next job, boost gauge...Cheers,
Grant
I've had like 3 or 4 head units, but as the third one started eating the battery...
