Top mounts
  • Top mounts
    So iv done about 300 miles with the current top mounts and they are f**ked again these where a set of gen ones. Iv tryed 034 motor sport up rated ones. Can some please tell me the best road to go down don’t want solid one any info on what you use would be nice thanks
    Do you have OEM struts?
      No I’m useing home made coilovers.
        Flat Out,
        If your set-up should use a mount of strictly OEM dimensions, perhaps these would be suitable?
          not intending to insult but are they the correct way up? It is possible to put them on upside down and then they will fail very quickly. Even the cheapest after market items should last longer than 300miles.
          Picture of installation?
            hi yes they are the correct way up ill try and get a photo in the morning
              If your top spring perch / spring collar floats on the shock shaft then I have a solution for you. Do you have any pics of your coilovers?
              Alex
                I don’t but they are bambridge coilovers kits I’ll try and he’s some photos
                  Alex
                  mine do...... whatcha got?
                    PM sent to Mr. Bambridge.
                      https://www.s2forum.com/forum/techni...-iv-a-new-hope
                      This reminds me to pull my finger out and finish machining the moulding tools in order to make these poly bushes.....
                      If you can wait a few weeks I will be able to supply a plug & play solution.
                        THIS sounds very good 8)
                        Project Audi s2 coupé 1996
                        http://http://www.s2forum.com/forum/showthread.php?t=80796]
                          As soon as you do put me down for an order Alex!!
                            That’s cool Alex I’ll wait no problem at all they look well cool
                            • #15
                              Count me in too Alex!
                              1996 S2 ABY Silver
