Top mount dust cover washer
  • 220bhp
    • 2578
    • Home: United Kingdom
    I am looking for the round rubber/plastic dust washer from under the front top mount dust cover on my s2 . Are they dealer only or are they available
    I am not having much luck finding them .
  • Nuvo
    • Nov 2003
    • 3825
    Do you mean the bump stops?
    • 220bhp
      • 2578
      No sorry I mean the washer that fits between the dust cap ant the top mount if that makes any sense
        • Dec 2017
        • 5991
        Still confused. On coupe at back there is a round foam disc. Do you mean that?
        • Nuvo
          • Nov 2003
          • 3825
          Okay, you mean the "strut stop" part number 811 412 319.
          I think these went NLA a long time back. I don't see them on Tradition or eBay.
          I think your best bet would be to post a wanted ad on here.
          edit: there are some available on eBay but they are way overpriced.
            This thing Lou?
            I've probably got one of these
              • Dec 2017
              • 5991
              I also have some if you are stuck.
              • 220bhp
                • 2578
                This gallery has 1 photos.
                • 220bhp
                  • 2578
                  No 2 in the diagram is what I am looking for
                    • Dec 2017
                    • 5991
                    What car is it for? Diagram looks unfamiliar
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      I have half a dozen of those if you mean the black plastic ring that goes on the outside of the upper sturt plate, which is what it looks like you're after.
                      1990 B3 2.0 80 quattro.
                      1992 C4 2.8 Avant quattro
                      1994 MTM RS2.
                      1998 B5 TDI quattro Sport.
                      2000 B5 TQS.
                      • 220bhp
                        • 2578
                        I am sorry for any confusion over both the part and the diagram . My s2 is at a garage having the strut mounts replaced as I am unable to work on the car myself any longer . I am going to the garage personally to try and find out exactly what they need .
                        many thanks for your help and apologies once again
                        • 220bhp
                          • 2578
                          This part is what is required .a pair of ,not sure if they come separate or not . I just need the plastic ring.
                          • Nuvo
                            • Nov 2003
                            • 3825
                            The plastic ring aren't available as a separate part it's bonded to the strut stop, they all split over time. You don't really need them.
                            You can use a rubber washer that sits below the strut stop as an alternative to the ring.
                            You can also use the strut stop from a TT or Mk IV Golf i think it is, these have a rubber bonded ring and the "hat" of the stop is a bit taller that the original item but it works. I'll post the part number for these once I find it.
                            edit: take a look at this page below for some details:
                            https://www.oemvwshop.com/1j0412319c-stop-p248889/
                            • 220bhp
                              • 2578
