Improving handling
    • 4754
    This question is kind of related to the how do you improve handling question.It might help some of us understand whats what as it would be beneficial as some of you have probably driven all these cars and have personal experience of what your thought were more comfortable and what was by far better handling. Apologies for the long one!!
    Am i wright or wrong your thoughts **VERY MUCH APPRECIATED**
    I find the S2 Avant and avants in general to be a better handling cars than the S2 coupe.The coupe is surprisingly comfortable. The 90 20v FWD saloon with the factory sport suspension was i thought a very very good blend of comfort and handling might be the best blend i have experienced from the B3 and B4 cars along with the S2 avant quattro being better.But weight plays a big part in it too the 90 20v being a lighter car.
    I have changed all the suspension on a 2.6 B4 avant not my current one but my previous one for new audi parts that's shocks,springs,bump stops,dust shileds,ball joints,drop links every bush inc wishbone bushes rear axle bushes and i found the car handled better for sure and much more comfortable firm yet supple and better insulated from ridges and bumps that these audis are quite bad for noise wise getting into the cab when suspension tired.
    I had a FWD J reg 90 20v saloon still do, but shell gone now along with all the bodywork. That car really impressed me with how comfortable it was yet still decent handling.It had cast front wishbones which i suspect are better handling than the pressed ones.Do the cast wishbones make that much difference.I suspect they do but not entirly sure by how much??No harshness coming through into cabin unlike what you get with the Avant on its original supension.
    My question is..why the big diferences. Did audi make different stifness bushes.For example would the standard Rs2 bushes be different to the rest of the B4 range?????
    Years ago i found that if you can find uprated rubber bushes the improvement is really noticeable.Nowadys eveybody seams to go the polybush route.But is that because its cheaper plus they last longer than OEM but more noisy.Sorry for the long one.
    • bartolomeus
      • Jan 2009
      • 1475
      • Country: Romania
      Originally posted by rynaqui
      So far this is what I've had, KW V1 suspension or better. Whiteline RARB on stiffest setting but this is very harsh and a front RS2 FARB but is not really necessary IMO.
      New drop links (stabilizer links - RS2 front (Thicker) and S2 coupe Rear)
      Wishbone bushes - Superflex or other polybushed
      Subframe bushes
      Renew ball joints and tie rod ends
      Diff hanger bush
      Refresh the under mounts, diff, gearbox and engine with OEM (I have not tried aftermarket here - takes around three-four hours)
      Front snub mount (Rusty on here is having a really nice set made up soon). This should reduce engine movement a lot.
      There is also the option of having wider tyres at the front as well
      Can you provide a link with the Whiteline ARB products? I went to their website but I didn't find it...
      So basically the easiest solution in ARB would be
      in the front : RS2 front ARB
      rear: S2 Coupe front ARB
      They match exactly no other mods?
      • bartolomeus
        • Jan 2009
        • 1475
        • Country: Romania
        Originally posted by Error404
        Best bang for buck IMHO is stiffer rear ARB, then poly bushes
        Which one? Do you have a link directly to the product?
        Also why not a stiffer ARB in the front as well?
        There are lots of example here but I cannot locate them anywhere on the Internet to buy them
          Seek and ye shall find
          • Lloyd
            • Apr 2006
            • 1559
            #20
            Neuspeed RARB, Poly bushes, RS2 H&R, Bilstein Dampers, Pro Mounts, Poly Diff and engine snub mount and track geo setup.
            RS2+ (now sold...)
              • 4754
              Only read first 2 pages but found seriously good info ref the anylitical mind of Rusty.Just what i am after.More happy revelations to read about in rest of link.Essential reading.Thanks
              • Bowie69
                • Nov 2013
                • 2675
                For info: http://www.camskill.co.uk/m14b346s43..._89-94_Quattro
                Pretty good price if you ask me.
                  B4 won't fit your coupe though
                  • Bowie69
                    • Nov 2013
                    • 2675
                    Not interested
                      I think Demon Tweeks do Whiteline ARBs
                      • bartolomeus
                        • Jan 2009
                        • 1475
                        • Country: Romania
                        #26
                        The webpage doesn't load from Romanian IP address... incredible...
                        Their IT guy must be :corey:
                          #27
                          Nah - more like Romanian ISP / DNS isn't finding it - link works perfect from philly airport !
                            #28
                            Set your DNS to 8.8.8.8 and try again !
                            • bartolomeus
                              • Jan 2009
                              • 1475
                              • Country: Romania
                              #29
                              Tried already from 3 ISP's... I really think they have blocked all Romania IPs....
                              • bartolomeus
                                • Jan 2009
                                • 1475
                                • Country: Romania
                                #30
                                I use Google's DNS all the time
