I have had some KW1 coilies and new hd top mounts waiting to go on my 92 s2 3b engine coupe. Today i had a couple of hours so fitted the front struts.
I put the wheels back on and the inside wall of the tyre drags slightly on the strut control arm and trackrod end.
I moved the camber so it is fully negative however the off side still drags on the tyre and obviously this seems a bodge way of getting clearance.
THe old standard strut arms were a couple of mil from the inside of the tyre anyway but never touched.
The car has 17 inch 245 40 tyres on audi bolero rims which I believ are off a B5 audi A4
The previous owner fitted these. Dont know offset.
I have a number of q's
1 has anyone experienced this with Kws?
2 Have i bought the wrong ones? I did but them from Yaz based on front axle weight and mine having m14 strut bolts.
3 What are my options. Different wheels? ( expense and just had them shod in new potenza rubber)
Return struts and try another set ( is it possible position of arm is slightly off?)
5mm wheel spacers? although I hate the things they also seem a bodge.
HELP.
HELP.
