1BE suspension shock replacement
  • hunker7
    • Mar 2014
    • 3487
    #46
    Wait, so is the shock piston shorter on 1BE suspension compared to standard suspension on UrS4?
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • RichLV
      • Mar 2015
      • 872
      • Country: Latvia
      #47
      I've measured the 1BA and 1BE shocks, length is the same. 1BE just needs sports gas shocks, which are stiffer.
      • hunker7
        • Mar 2014
        • 3487
        #48
        That's good to know. So as long as they're gas shocks they're fine?
        '93 Audi UrS4 Avant
          Originally posted by hunker7
          I personally couldn't find Sachs or KYB shocks for UrS4.
          I looked for KYB info and couldn't find any. However I did find some Sachs info:
          Here is some Bilstein info:
            • 4754
            Thats what i said No2 post in this thread.
            Originally posted by Vorsprung durch Technik
            As you have IBE sports suspension Janis you need Gas pressurised shocks,just make sure they are for the S4/S6.
            • RichLV
              • Mar 2015
              • 872
              • Country: Latvia
              #51
              Sports gas shocks. They're stiffer.
              KYB Ultra SR fronts PN - 376001
              KYB Ultra SR rears PN - 351020
              • hunker7
                • Mar 2014
                • 3487
                #52
                ...and you also said to make sure they're for UrS4/6 and thus wanted to know if piston is shorter or it's just the spring. Because on B4 sport suspension rear shock piston is shorter compared to standard.
                '93 Audi UrS4 Avant
                  The gas in the shock basically assists the spring and also stops the oil from foaming.
                  • igor136
                    • Jun 2014
                    • 363
                    • Country: Croatia
                    #54
                    Thanks,
                    Sachs is cheaper but not bad. All new shocks are better than my 20 years old.
                    Audi have answer for us:
                    1-2-4-5-3
                      • 4754
                      Standard suspension and sport 1BE suspension dampers are the same height i.e. have the same piston travel the only difference is the sport is Gas pressurised which is firmer which gives a more precise controlled ride. As you have 1BE sports springs you will have the gas shock form audi. So if your keeping the 1BE sports suspension for now you will need Bilstine B6 gas shocks.Only if your lowering more than some do will you need Bilstine B8 gas shocks which are the same gas pressurised rate as the B6 only they have a shorter piston travel to match lowering springs.
                      • igor136
                        • Jun 2014
                        • 363
                        • Country: Croatia
                        #56
                        This is my car with 1BE suspension and B6 shocks. I think is little bit to high in front. In front are new shocks and rear are 1 year old. Bilstein B6 all
                        Poslano sa mog SM-G532F koristeći Tapatalk
                        1-2-4-5-3
                        • igor136
                          • Jun 2014
                          • 363
                          • Country: Croatia
                          #57
                          1BE + B6
                          1-2-4-5-3
                          • igor136
                            • Jun 2014
                            • 363
                            • Country: Croatia
                            #58
                            One more
                            1-2-4-5-3
                            • hunker7
                              • Mar 2014
                              • 3487
                              #59
                              Front being higher than rear is down to Audi springs.
                              '93 Audi UrS4 Avant
                              • igor136
                                • Jun 2014
                                • 363
                                • Country: Croatia
                                #60
                                Yes. Audi springs and B6. New oem bushes
                                1-2-4-5-3
