Billcatz Short shifter modified :-)
  • Martynf
    • 1885
    I fitted the Billcatz short shifter a few weeks ago which is a real nice short throw, but the short shifter does NOT have reverse gear lockout on it! :eek2: it was WAY too easy to hit reverse from 2nd gear or neutral and 2nd was a pain to get sometimes.
    A solution HAD to be found.
    A solution has been found I now have a sweet short shifting gearbox WITH reverse gear lockout back in place!!
    Now I have reverse gear protection back, I can NOW 100% recommend this short shifter providing you do this mod....Click here
    Martyn
    Martyn
    www.vagparts.com
  • Mark Halligan
    • 2001
    Nice write up Martyn,
    I think I'll have to get one of those when I can afford it............ putting it on the BIG list of things to do .
    Cheers,
    Mark.
    Mark - Modded
    • Martynf
      • 1885
      Cheers Mark!
      The list never gets shorter does it? Think I paid about £80 all-in for the shifter from the guy in the US. It's worth doing.
      Martyn
      Martyn
      www.vagparts.com
      • Audi Parts Guru
        • 1317
        Nice one mate can you do mine next time you're down the warehouse
        S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
        • Martynf
          • 1885
          Sure no problem! grab yourself one of the shifters, but you'll have to bring the car to mine to be done
          Martyn
          www.vagparts.com
          • sal_s2
            • 1287
            Group buy anyone???
            • Martynf
              • 1885
              The guy selling these (Richard Hoffman) did say he would do them cheaper for a 'quantity', also the shipping works out a lot cheaper if you buy a 'qty' from him in one go.
              Martyn
              www.vagparts.com
              • sal_s2
                • 1287
                Plus free fitting by MartynF
                Cheers Martyn
                • Martynf
                  • 1885
                  I don't mind!! long way to come to get me to fit it though!!
                  Martyn
                  www.vagparts.com
                    Well i dont mind travelling for your services in fitting matey lol
                    • Martynf
                      • 1885
                      no problem!, I'll do it when you've got yours back on the road, so I can see how I've got to plumb my turbo
                      Martyn
                      Martyn
                      www.vagparts.com
                      • Glen Chamberlain
                        • 375
                        whats the advantage to the short shift? Does it make 2nd gear selection better or worse? Cos its not the best gear to get really is it?
                        Money is everything! Second to Power of course!!! But money breeds power??
                        • Martynf
                          • 1885
                          I got it because I really like a very small amount of movement when changing gear. The S2 has a slow gear change, so this part reduces the distance between the gears and makes it a 'quicker shifter'
                          I had a Passat GLS 100hp back in the early 80's whose gear shift is still the best I've ever had! The movement from gear to gear was about a 2 inch move! a real nice 'snick' gear change!
                          You'll never get that with the S2's lazy gear change, but this kit means you have less distance between the gears, therefore a faster change. 2nd gear is simple to get, but maybe my box is ok on 2nd...
                          Martyn
                          Martyn
                          www.vagparts.com
                          • Doug_RS2
                            • 3847
                            I'm up for a group buy on this.
                            Nice one Martyn
                            • martinjs
                              • 3205
                              id be interested in one also, been thinking about it for last couple of months, martyn, will this mod apply to 3b's also as reverse is opposite to fith??
                              martin
