i'm really not sure now it could even be an NM 2.0 20v
Hi I need all your expert help with flywheels
Right , I would of helped if you had taken the photo from the top as you may be hiding the pin from the angle of the photo , however from the diameter of the ridge I don't think there is a pin so it is most likely an NG .
For reference here is a pic of the back and front of a 7A flywheel, note the pin on the back next to the ridge and the diameter of the clutch contact surface on the front.
Attached FilesComment
Just to add to the confusion, that flywheel looks like the Audi 100/200 3B engine as it dosent have the bearing. Vs S2 3Bs that have the centre bearing.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
It's been said the 3B is the lightest, anyone put and actual figure to it in Kg.
Looking at a lightened flywheel possibly next year but do not want anything radically lighter that it upsets the normal running. Cheers1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
2011 A5 sportback 3TDi-Backbox delete, remapComment
NM and 7a uses the same flywheel,that part number you gave IS a 7a/NM flywheel,the chance of finding an NM engine is the UK is slim to non anyway
