RS2 Tranmissions - CGR vs CRB
Thanks. Answered. Mid-Oct. 94 build so the CGR seems to make sense.
The end of Oct. 94 was 00794 so maybe if someone PMs me their VIN and the transmission code (from their build tag) for an RS2 just above the 00794 VIN, we might get lucky and find the Nov. 94 break-point on CGR to CRB.RS2'd 93 UrS4 5 spd sedan
My RS2 is a 95, built in 94. As Billman's it also has a CRB installed, despite the build tag listing CGR.
I have assumed that it was replaced sometime between 1995 and 2001 (when it was exported to Norway), but since Billman's had a CRB installed at the factory, despite the build tag saying somethinge else, it could well be the case for mine as well.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
Are you the original owner? Unless you are, I suspect that the original transmission was a CGR but it failed under warranty and was replaced with the CRB before you got the RS2.
What was the build month? VIN SN000nnn? (PM me if you want)RS2'd 93 UrS4 5 spd sedan
Maybe. I can't see them making a mistake like that unless it was on the day of the switch-over from the CGR to the CRB, in which case finding out Billman's VIN number might be interesting. e.g. early Nov. 94 build?RS2'd 93 UrS4 5 spd sedan
Would be interested in info on the DPH gearbox in my car, I hear it is a good gearbox, but don't know if this is an evolution of other gearboxes?Audi S6Comment
The DPG and DPH both have the 01E311105J (wider 1st but not flexible) main shaft. The CMG and DPJ have the 01E311105H (wide 1st and flexible) main shaft, same as the CRB.RS2'd 93 UrS4 5 spd sedan
