Clutch kit recommendation 500+ hp setup
  • Laaf
    • Oct 2010
    • 275
    I run a SRE 707 pressure plate with a SRE 8-puck sintered clutch with springs, quite harsh on a light car but nothing impossible to drive. Turbo was a 3071 sized one which ran about 440-450 ish hp, torque unknown.
    • Sonic
      • Jul 2006
      • 5514
      Originally posted by snp10
      This was a stage 3+ from Spec?
      Originally posted by quattrostyle
      No a Soutbend.
      ^^ Southbend.
      S2Forum.com Administrator
      • snp10
        • Nov 2012
        • 189
        • Country: Romania
        Any other options except Sachs/Spec/Southbend ?
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          Southbend is **** in my experience
          From what I tried, I'd buy again and again a SPEC stage 3+ clutch kit
          Holds fine a GT30R and very very very comfortable
          • SteveH
            • 4460
            Clutchnet
            91 Modded 3B
            14 A6 Avant Black Edition
            • andy10v
              • 5996
              I was told Keith Edwards and Keith Murray of Dialynx use a Helix clutch.
              Sold ABY-stock
              • EspenW
                • Apr 2007
                • 1534
                • Country: Norway
                #22
                Stock RS2 clutch works fine in me ride.
                1994 80E Avant
                1986 2L Golf 2 on Alcohol
                • snp10
                  • Nov 2012
                  • 189
                  • Country: Romania
                  #23
                  I heard some good opinions about Spec. For what I know they are using Sachs p plates . Are confortable for daily driving.
                  • quattrostyle
                    • Oct 2006
                    • 6229
                    When I first joined here I read no good about Spec clutches, but now Southbend is also no good?
                      #25
                      imho, if SRE can't make a good clutch who can ?
                      The size of the company and resources that they have at their disposal and the years of experience is pretty big, compared to the other two.
                      I would choose SRE over Spec and Southbend. Over the years on here I read bad reports on Southbend, and even more on Spec. Don't think I've even heard of any issues with SRE. Just sayin........
                      I have a Southbend and a 7a flywheel on a fried ABY and it is not comfortable to drive from a 'snatchiness' point of view, I'm not driving it for the last year, as I've 'upgraded' to UrS6s. I haven't taken the S2 apart to see what the issue is, it may not be the clutch, but may advice to the op is that they should spend the money on the appropriate clutch SRE as it will work fine, and you won't have to take it back out again. That's what I hate about about a big awd car is changing the clutch or the gearbox on my driveway.
                      Once any financial pain of buying decent clutch is absorbed, you'll enjoy the benefits of a decent clutch working for years with no grief or concerns during that time. Don't be tempted to cheap out on quality because of a perceived high price. SRE is cheaper in the long run as it will be a case of measure twice and cut once.
                      Just my own tuppence / biased experiences.
                      • SteveH
                        • 4460
                        Yes, Helix have a good name, but aren't cheap. They are worth looking at if you're going multi-plate. They are UK-based which is good for us in blighty. They also supply a metal faced release bearing at sensible price.
                        91 Modded 3B
                        • snp10
                          • Nov 2012
                          • 189
                          • Country: Romania
                          #27
                          The SRE are good clutches , but bouth disks provide it , supports only 520 NM. With gt3076 the torque will be higher.
                          • Thuppu
                            • 4115
                            The stock AAN clutch will be fine with 500Nm. But just go with tripple Tilton to be sure.
                            • andy10v
                              • 5996
                              I contacted Helix to ask about max torque
                              This organic fast road clutch will take approx. 340 lbs feet of torque, maybe a bit more.
                              The paddle will take approx. 400 lbs feet of torque.
                              The paddle can be used on the road if necessary but will be quite hard, you cannot slip it in traffic and may get clutch judder upon take up, although it is ideal for race and rally.
                              Sold ABY-stock
                              • snp10
                                • Nov 2012
                                • 189
                                • Country: Romania
                                #30
                                Spec said that stage 3+ will take about 565 lbs at the crank.
                                I had some bad experience with a paddle disk on my Astra Opc. The clutch didn't slipp at all and if wanted to get out from an underground parking place was a disaster .
