Ok,
Damn it guys - i am seemingly upgrading my car without knowing it step by step Mark/Doug you have a lot to answer for
How easy is it to mount a Porsche 996 caliper as I have found a very cheap source for a pair. Does anyone have any dimensions for the bracket that would be required? Would it be possible to use the rs2 caliper bracket to bolt this caliper to? Also I guess next issue then is disc size and availability.
I am going to change the wheels for 18's - thanks Doug u arm twister shortly
Finally -in the land of dreams, whats the potential maximum disc diameter/caliper setup i could run behind an 18inch 9 spoke rs4 alloy?
£££££££££££££££££££££££heer s,
David
David
