peterp - not that I don't trust you but have you any pics or links of 323mm disks under the 16" Avus's?
Looks fairly tight with 314s....
David, no its actually a US 200q20V Avant - but I'm guessing they share a few bits!.
Just need to check what material these guys use & how they'll treat them...
I didn't reaslise Quite how popular this conversion already was!
Yoggi - did the RS2 brackets require any spacers or washers to make them line up properly?
And does the edge of the pad line up with the edge of the disk?
I guess the next question would have to be to Martyn - a price for those little RS2 brackets?
EDIT: £75.50 ea + VAT - thanks martyn!
PS some really cool pics on your site there yoggi!
996.351.425.11 Left Front
996.351.426.11 Right Front (as far as I know the last 2 digits refer to the colour)
and are used on current model carrera 4 and carrera 2
The turbo'd 996s use a variation on the big reds and are a totally different cup of tea.
Clearly front and rear are different - but the difference appears to be only the piston size. Looking at a front and rear side by side there are only very subtle differences.
These calipers are also used on the current Boxster S (and in this case are known as M008s). The regular boxster uses similar looking calipers but are only for 25mm thick disks. Ask any more Qs as necessary - I've now got the Porsche version of ETKA so think I know it all!
Originally posted by Alistair C doug - you know you can get 'spinning' valve caps that require a tool to lock in before you unscrew them..... from richbrooke?
I did not know that - I'll have a look into it - got a webpage to hand?
On the subject of porsche callipers again, if the audicoupe.de site is correct about only needing a couple of washers along with the RS2 brackets I can feel my big brakes getting a hell of a lot closer.
Has anyone confirmed this can be done?
Ben
