Bo : this was my exact thought, hmm cool enough, but yes, maybe lupo can supply this if possible?
There has to be a high hp goal also on this?
We are hoping for 600+ on a std head with gt-35 turbo.
Will put up the RR when finished
Wagner Inlet Install Questions
This is a sticky topic.
You can put it there, between the IC and the TB.
Looks a bit like this then:
Its not easy though as the hose supplied with the kit is about 1.5mm to narrow to have the MAF fitted in to it so you have to join two reducers to it. Its a PITA as its very tight for space in there and takes a lot of trial and error.
Maybe Lupo911 can make the next batch of hoses so they would fit the MAF it one was cut in half. That would be great!!Leave a comment:
Ive just put this whole kit on my friends RS2 here in denmark, and what a super kit it is.
Just need to find out where you guys put your MAF if you have upgrade turbo´s on it as there is NO MORE ROOM in the em side.
Put it in the cold side just before the im?Leave a comment:
i use diesel leak off pipe on all vac hoses,as it is very strong and has a nylon overbraid same as the origanal
i thought the cable was non-direct fit...i also have to extend at the pedal endLeave a comment:
Just bought on the bay of thieves some 6mm hose and a 6mm to 8mm hose connector
Another question what size vacuum hose have people used? the 5mm standard don't fit tightLeave a comment:
S2Martyn cheers was just about to post I measure today manifold connector is 6mm with the barb being 7mm and the other end being 8mm
AAN cable is not a direct fit, having to extend my cable.Leave a comment:
no its 6mm ..its 8mm on the valve end but manifold connector is about 6mm....i used 6mm pipe and sqeezed it on the valve end by putting the pipe i hot water....
also is the aan cable direct fit?and part number?Leave a comment:
Is the hose definitely 8mm?
It is 8mm at the carbon cannister end but the big nipple for the manifold seems smaller than 8mm and the hose does not grip it.
If it is what hose have other people used? Silicon fluoro lined?Leave a comment:
What throttle cable are you all using? Is an S6 one the right length?Leave a comment:
The Tube comes with the full Kit (Intake and Intercooler Kit) or just with the Intercooler Kit. If you have the Manifold allone, it comes not with it.
If you want to use the ISV Valve, its no Problem, we deliver all Parts to get this mounted to the Manifold.Leave a comment:
re
thanks carsten....does the isv tube pictured come with the manifold or kit?my manifold has no hole for this to be fastened to!!Leave a comment:
i also need a few answrers to my inlet installation
1/what happens to the dipstick tube bolt? that will mount to the ISV Valve Tube, only on ABY and ADU, 3B doenst need it
2/does the pcv valve go to the manifold?or can i remove it? no that goes to the Manifold, it will be mounted to the Same Tube like on the picture above
3/will i get any errors not using carbon cannister? No, errors, but our Manifold has the connector for the Carbon cannister...
does anyone have any install pics?
thanks martyn
@Sonic, you are rigth, its just a Universal Part, because the most Guys are using different Turbos, its hard to make a Hose that will fit allLeave a comment:
I haven't changed any of the vac hoses of yet
