Nightmare S2
  • Tonks4x4
    • Nov 2005
    • 3062
    Thanks for the comments guys I'm glad it's not just mine...
    I have finished what I can do today as all the welding is finished, all the welding and bare steel has been primered. Once this was dry it has all been seam sealered on every joint.
    This has then been left to dry all day with the heater on it.
    And to top it all off its now had copious amounts of gravitex applied to dry over night.
    Then Monday it will be primered and painted with crystal silver inside the boot and gloss black underneath.
    I have also acquired a 1.5kg tin of genuine dum dum to seal the rear lip inside the boot and to fit around my all red rear lights
    Audi Nut!!!
    • sidrick
      • Jan 2011
      • 1342
      You got a price posted to Aberdeen for those fuel lines? They look better than mine
      • andy10v
        • 5996
        You dont hang about do you Brian!
        Sold ABY-stock
        • Acidburn
          • 13459
          I found the majority of the coupe's i've had seem to go at the point behind the fuel tank in the little pocket on the passenger side. I'm not sure if the heat shields just holding dirt/etc as most seem to have fallen off by now or if its just the rear lights always leaking into that part of the car and into the section underneath the removable container underneath the drivers rear light (rhd models)
          • Monkeymagic
            • Mar 2012
            • 3419
            this has made me paranoid now. I've just had a look under the boot trim and under the car along the seam. thank god for that. i hate rust aka mini.s and mk1 golf!
            • Monkeymagic
              • Mar 2012
              • 3419
              i may drop the rear bumper off and give a light coat of dinitrol.
              nice neat welding Brian. my mate re built a volvo p1800 i was amazed. good welding is an art form. i
              • dunstan
                • Apr 2011
                • 103
                Its not too rusty and at least you stopped it now.
                I did fuel lines when i swapped in the 3b to my b2. I ran them passenger side rigt up to the bay. Further from the turbo
                  Originally posted by Error404
                  BTDT I know how you feel Brian, you have my sympathies.
                  I had to exactly the same thing on my coupe 3 years ago.
                  +1 nightmare..
                  Looks really tidy now though Brian and all sorted quickly too!
                  • benntenn67
                    • Jun 2009
                    • 859
                    Originally posted by bilko0795
                    Nice bit of welding there old chap
                    Originally posted by Biggss2
                    Yes, must commend you on the welding, very neat.
                    ^^^^ Indeed, I doff my cap to you sir - your welding & fabrication skills are exemplary
                    Audi S2 Coupe 1995
                    VW Passat GL5 (hatch) 1986
                    Carrera Subway 8
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #25
                      Holy crap! I thought mine was bad when I poked around underneath, but now it seems like a minter.
                      Lucky the car is in the hands of Tonks. I fear that would have been a scrapper for most. Top work, as always Mr T.
                      SS
                        Thats a hell of a lot of work to get done in that time. Well done and you deserve a few Been getting some preemptive maintenance done on mine over the last year or two, hoping to avoid a massive job like this.
                        • Tonks4x4
                          • Nov 2005
                          • 3062
                          Good old Tom got cracking with the paint today while I was working on Land Rovers.
                          Now it's dry I have just dropped the tank in.
                          Once the little one is tucked up in bed I will go back down and carry on,
                          Here is a couple of pics for now...
                          And the pipes are now connected
                          Audi Nut!!!
                            Wow. I had no idea that the S2 fuel tank was not between the rear wheels like a C4. How many rear-end accidents end in a fireball (thinking Ford Pintos)?
                            The good news is changing the fuel pump must be a piece of cake.
                            • Tonks4x4
                              • Nov 2005
                              • 3062
                              Never thought about rear impacts but guess I will not be around to worry if it happens lol
                              A little about tonight's tasks....
                              While everything is out is a good opportunity to do the relay mod on the fuel pump so that it gets a higher voltage.
                              And while I am this far in I may aswel sort some other niggly issues!
                              So the rear quarter card came out to inspect why the central locking has stopped working. I found that the pump had just died so swapped that out and all the doors lock as they should.
                              While this was out I have now fitted the later style B pillars with the infrared sensors so that I can wire in the factory remote locking at some point to get rid of the aftermarket stuff.
                              And seeing as the quarter card is out I felt that now is a good time to fit the switches for a later upgrade that I have planned.
                              I have opening rear windows and its rubbish that rear passengers can't open them from the rear and also I have some heated seat elements to wire into the rear seats at some time so....
                              Audi Nut!!!
                              • tscheel
                                • May 2009
                                • 222
                                • Country: Denmark
                                #30
                                I'd say that you can wear that "Audi Nut" badge with pride, Sir.
                                Cheers, Torben
                                '94 B4 Avant S2
