Jack4688's S2 Avant
  • Jack4688
    • May 2010
    • 1004
    Had a delivery from quattro corner today
    Also had a pair of cams arrive earlier from Error404
    • Jack4688
      • May 2010
      • 1004
      Fitted S2 Recaros to the Avant this weekend
      They are surprisingly different from the MkIII Golf Recaros I had in before. More side bolster and more leg support. My knees are a little bit higher than before which will take some getting used to but these are still better than the old ones!
      Not sure what to do with the old Golf ones now. Thinking of either selling them or I might get a B4 quattro once I've settled in to my new house, turn it in to an S2 lookalike
      • Jack4688
        • May 2010
        • 1004
        I've been procrastinating today - should be re-writing my CV, filling in some life assurance docs and renewing my driving license. But on the plus side I did tax my A4 when I've had 10 days to do that So right now instead of doing all that boring stuff I should be doing I've been looking into my cambelt change.
        I picked up a set of crank locking tools from JMLAudi today and have had both a new cambelt and crank position sensor from Error404 for a while now. My question is: what else do I need for this job, regardless of time since the last cambelt change on this car? If my memory serves Tristan and Kit did the cambelt change before I bought it as we couldn't see any service history for some ridiculous number of years, knowing it had most likely been done but just wanted to be on the safe side.
        I've 'lost' my torque wrench but I'm sure it didn't go up to 200Nm anyway and I'll need a bit of scaffold for undoing some of those pesky bolts. Are there any other parts I should change as a matter of course, such as seals, aux belts/pumps, general bolts/nuts/fasteners or any extra tooling/consumables I haven't thought of? The item that needs replacing is the crank position sensor but I thought changing the belt would be advisable rather than putting the used one back on. I've had a read through the Timing Belt Renewal pdf on S2central and noticed one of the stickys under Engine & Turbo recommending that the crank pulley be changed.
        The time since the last cambelt change is just over 2 years and around 10-12k miles. Also, given that the car is SORNed and the MOT expired I have no reason to set myself a time limit on getting it done (hence procrastinating), but on the other hand I don't want to create any unnecessary work for myself given that this is my first crack at doing a cambelt change.
        • andy10v
          • 5996
          Are you changing the cam position sensor? The crank position sensor is at the back of the engine on the bellhousing.
          If you are doing the cambelt I would do
          cambelt
          crank pulley
          tensioner
          water pump
          thermostat
          aux belts
          crank seal only if leaking
          I think cam belt is 60-70k/5 years or so
          Sold ABY-stock
          • Jack4688
            • May 2010
            • 1004
            Yes cam position sensor is what I meant
            Looks like I've got some more parts to buy...
            • andy10v
              • 5996
              At that time/milage you can replace the sensor without replacing everything else. Or do you want to not have to go back in again anytime soon.
              I forgot coolant if you do the thermostat and water pump.
              Sold ABY-stock
              • Jack4688
                • May 2010
                • 1004
                I don't mind going back in in a couple years, it's just the cam position sensor needs replacing as it was stopping the engine from restarting if it had got up to normal operating temperature. If I do a minor job of it doing something a whole lot more thorough might not seem so daunting in a few years time.
                I thought, from reading the walk through on S2central, that the coolant would need doing anyway as the rad needs removing to get to the belt?
                • Trist28
                  • Dec 2008
                  • 725
                  #113
                  From memory........
                  I changed the crank toothed pulley, waterpump, timing belt, tensioner, thermostat and aux belt. Crank oil seal was dry.
                  I did mine and the one you bought at the same time. If you want to learn, take it apart and change again, but with the mileage done its really not needed
                    The cam sensor is quite an easy job, you only really need to take off the front belt cover and the cam cover.
                    Remove belt cover and release belt tension
                    Remove cam cover & counter hold ext cam with mole grips (or use an appropriate locking tool)
                    Undo cam pulley bolt and remove cam pulley
                    Change hall sender
                    Refit etc
                    No need for bumper and cross member off, or crank locking tool etc
                    • Jack4688
                      • May 2010
                      • 1004
                      Originally posted by Trist28
                      From memory........
                      Didn't realise you two did all that That's good enough for me I'll just do this c***ing cam sensor!
                      • Jack4688
                        • May 2010
                        • 1004
                        Change hall sender
                        Refit etc
                        That sounds more my speed
                        • Jack4688
                          • May 2010
                          • 1004
                          On a different note, I now have a Garrett GT3582R
                          Because why not
                            Want some rods and JE pistons to go with it?
                            • Jack4688
                              • May 2010
                              • 1004
                              Do I need them? Or can I get non-silly power from it with just changing the injectors and fuel pump?
                              • Jack4688
                                • May 2010
                                • 1004
                                Is this a crack in my exhaust manifold?
