Vagsports / Delta Not just quattronics then
The forum is littered with links from him down the years, how do these cockroaches survive?
It could just be that not enough is mentioned about people over the years to newbie's etc?
I'd only dealt with him thru ebay with luckily only one bad experience and only found out more when I came on this forum and read thru old posts by delta and vag-sport.Comment
This is him on motorgeek
its a small world. somethings....namely certain individuals morals and consciences......never change. The same names banded around year after year. As Jamo posted on srs, siena predates Corey by a good few years. Its odd going on newer forums and seeing the same names popping up...and you can see how the certain individuals weedle their way into various forums/groups
GavS2 Cabriolet.........
Does anyone on here remember the state the Bacofoil express came back in?
IIRC the oil return pipe from the turbo was bolted back on to the block with the self tappers from the front end cross member!!!91 Modded 3B
14 A6 Avant Black EditionComment
he also goes by the name of "laurence" had this guy phoning me up to discus about a v8 project he is using the same ecu as me, after having a chat with my ecu man it came aparent that this was actually siena!!!!!!
If anyone has bought flywheels off him, be aware that some of them have been cracking around the bolt pattern due to the wrong grade material being used, this could have very dangerous conciquences.
I only have this information because he "laurence" told me over the phone and couldnt understand why it was happening.
not slagging here just be aware of what i have heard from the horses mouth, if a flywheel lets go it is not a pretty sight.
