Audi 80 Saloon S2 nearly finished!
  • sjw185
    • 1175
    Yes more pictures, looks awesome
    Information about the saloons diet and is there any spare door cards left
    cheers
    Steve
    • will20v
      • May 2007
      • 391
      i will post pics of the diet for you tomorrow.
      i have taken anything that was not needed out of the car and replaced windows with polycarb ones apart from rear 1/4 small ones and screen for strength.
      fuel was massive and weighed loads so binned it all the plastic inside bits inc dash and unused wiring looms were cut out. sunroof mech removed and welded up.
      i put it on the corner weights with the glass in and not the polycarb windows and it weighed 1268 kg but there was no water in the engine or rad so they will probly cancell each other out. i removed the abs and used a AP brake bias lever to sort the rear brakes locking up.
      the engine flywheel has been on a diet 5.8 kg it weighed .
      i also moved the engine back slightly but only 20mm so not a massive amount but it all helps.
      its on koni and h+r in the pics but there is no weight at the rear so its sits high at the back but i will sort this tomorrow with a coilover kit
      front brakes are 323mm discs and 425/426 monblocks from a boxster s
      rear brakes are s4 300mm with s4 calipers from a B7 soon to have monoblocks when i find some for less than the national debt.
      downpipe and exhaust are 3inch homegrown with a rs4 b5 rear silencer to quiet it down a tad.
      more pice tomorrow of inside and coilovers on i hope
      • sjw185
        • 1175
        Was intrested in the registration of your saloon with the DVLA,
        Does it stay as a V6 80q with a engine change or is it a s2 saloon on the reg doc?
        Thought it would be easier getting insurance if it was called a s2 as you would get insurance quotes based on a s2 avant with mods?
        Steve
        • will20v
          • May 2007
          • 391
          Steve
          Its a 80Q v6 2.6 on the logbook but i have a traders policy and can drive anything so its not a problem for me to be honest.
            Nice build Will - is it caged?
            What width / ET are the CHs and what rubber are you running on them?
              I want one of they.
              Looks really subtle but will be scarily fast with that power, nice work Will!
              • will20v
                • May 2007
                • 391
                et35 8.5 inch for all 4 wheels 225/35/19 rubber
                i am doing the cage soon just need to run the engine in and get it mapped when Minea is back 1st week in Jan
                • quattronutter
                  • Jan 2005
                  • 690
                  most important question is when do i get to go for a ride
                  • yavor20v
                    • Apr 2006
                    • 163
                    • Country: Bulgaria
                    #39
                    Niiiiiiiiiiice!My next car project after few years (i hope) will be the same !
                    I love it!
                    Need more pics!!!
                    • Dan
                      • Jun 2008
                      • 1242
                      Good job
                      Hope I can see it in the flesh at some point
                      1993 ABY Coupe | BMW R1200 GS
                      A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
                      • UR-S4
                        • 159
                        How did you adapt the engine mountings? Did you graft on some 5 cyl ones or make some new engine versions? Thats my next concern!! (I have donors to chop out)
                        AKA "THE THREAD KILLER"
                        99 A6 V8 saloon
                        85 UR Quattro
                        01 Sharan v6 4motion
                        91 Golf gti cabrio sportline
                        95 Audi 80 DS2 saloon. project "SWEEP"
                        95 Audi 80 quattro v6.(but i have a 3b engine sat on the floor)protect "SUE"
                        • quattrostyle
                          • Oct 2006
                          • 6229
                          I believe that the B4 4, 5 and 6 cylinders all use the same chassis engine mounts. Traverse and radiator mounting points are different.
                          • Skull
                            • 3506
                            • Country: Slovenia
                            #43
                            4 and 5 cyl engines have the same mounts, 6 cyl have different chassis mounts
                            Audi Quattro WR
                            • hermanio
                              • Jan 2009
                              • 800
                              +1.
                              5 Cylinder Freak
                              • UR-S4
                                • 159
                                I know about the differances the question was how did you adapt a 6 cyl to accept a 5 cylinder engine.
                                99 A6 V8 saloon
                                85 UR Quattro
