Hellp s6 2.2 turbo no power on load
  • Audis6quattro
    • Jul 2010
    • 48
    Hi everyone
    I have a problem with my 1995 audi s6 c4 2.2 turbo when I drive in normal mode like city everything is ok when i go on motorway and want to give gas to the floor the engine loses power , judders and can't get more then 4k rpm at all, as well loos speed instead gaining it . Even i trade at home and cannot get 4k rpm Just doesn't go over 3500 RPM I don have any engine upgrades
    Maby some one had similar problem
    Thanks in advance
  • vonbeck
    • 2455
    Boost leak/ dirty maf?
    ABY Cricket Green Pearl Coupe, blk leather
    THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
      • Dec 2017
      • 6006
      I had this and it was the fuel pump. As said above, could be boost leak, maf pins etc, etc, etc!
      • Audis6quattro
        • Jul 2010
        • 48
        I check all pipes no leak. and its boosts until around 3500k rpm and than its like choking up.
        • Audis6quattro
          • Jul 2010
          • 48
          and when its choking up I can small fuel, its like it over fuel or not burning fuel
            Pull codes with Vagcom
            Do a proper boost leak test, plug the MAF hose and pressurise to 1 Bar.
            • DEREKCO
              • Feb 2009
              • 435
              Hello guys reading this post reminds of the time I had a similar problem with my S2 it turned out it was the catalytic converter had collapsed blocking the exhaust ok up to 3500 rpm then checked just a thougjt
              • Bowie69
                • Nov 2013
                • 2680
                Could also be knock sensors, pull codes from the ECU and see what's what.
                • Swizz
                  • Dec 2019
                  • 8
                  Check the engine timing and also the recirculating blow off valve
                  • 89 Coupe
                    • Aug 2016
                    • 125
                    • Country: New Zealand
                    Had the same problem on my 96' S6, cats were completely collapsed, could not build any boost.
