Group Buy: Front Tie Rod adjusters
  • Group Buy: Front Tie Rod adjusters
    Following on from the work that Bambridge did before I am looking into getting more tie rod adjusters made with 17mm AF adjuster in EN16T. I am getting pricing for them at the moment and wanted to gauge how much interest there is for these to get an idea of batch size to get made.
    At the moment the prices I have had back so far would put a pair with delivery between £24 and £30 including postage. The spec would provide an 8-10mm width on the 17mm AF section so they would have a lot more material to get a decent purchase for adjusting the tie rods.
    Previous info on them https://www.s2forum.com/forum/techni...djusters/page2 and https://www.s2forum.com/forum/techni...-rod-adjusters there is details of QH5005S ones being compatible, but looking around they are a similar price to the improved design with the larger adjuster I am putting forward here.
    20
    I would want to buy a pair of tie rod adjusters with 17mm adjuster
    70.00%
    14
    I would want to buy two pairs of tie rod adjusters with 17mm adjuster
    30.00%
    6
    And how about the rear ones? Coupe
      Hi Greg,
      I'd be happy to buy a pair for one car to have a set on the shelf.
      Thanks for looking into this.
        Hi Greg,
        Would they fit 1994 URS4 ? Are they rose-joint? I will be interested. thanks
          I will need to check if they fit the rear too, I expect that will do but will need to confirm.
            Originally posted by kj6304 View Post
            Hi Greg,
            This isn’t for the whole arm, just the threaded adjuster for setting up the alignment since you can buy the tie rod ends but not the adjuster easily which is usually the part that gets rounded off when adjusting alignment.
              I'll have a pair if they fit the rear Greg (already have them for the front)
                that would be great. in that case I'll have to vote again in the poll
                  Will they fit the Avant?
                    Yes certainly front arms, I need to confirm on the rears
                      Ok, I'm replacing more or less everything so put me down for the fronts. Rear as well if it will fit.
                        Put me down for a couple of pairs Greg
                          Before I got through parts catalogues can anyone tell me if the tie rod adjusters are the same size front and rear on the coupe and are the same on the avant too?
                            Hi I’d like a front set please thanks
                            • #15
                              I'd take a pair for my S4
                              '93 Audi UrS4 Avant LPG
