Yes I assume this would be the main concern. Regarding the material then it is the same as Carsten used, but with 2% more nikkel. I'm not a material expert, so I can say what effect that will have on the manifold.
The moulds are the same, so that should yield the same result.
Then there is the machining of the manifold afterwards, but again I dont think this should be a problem.
