Audi Coupe OEM+ Interior Lighting Guide
This is a sticky topic.
  • Jas11n
    • 5067
    Been meaning to do something like this for a while now. After sitting in a beautiful red B7 RS4 last weekend and having noticed it's footwell lights, I thought I'd get my butt into gear and do it.
    I wanted them to come on and go off with both the central locking and opening/closing the doors. Wasn't bothered about being able to manually switch them on/off.
    I linked into the rear interior light mainly because of not wanting to tempt fate in taking down the front interior light and sunroof rotary control panel. I've seen SO many of those broken over the years. Best leave as is.
    The interior light at the rear easily clips down, just push it towards the drivers side and pull the passenger side down at the same time and out it comes.
    I needed to determine which live I needed, that being the switched live from the central locking and the door switches and not the permanent live that is there for switching the light on at all times. Didn't have my multimeter at hand, so just used a spare LED I had. Opening and closing the door allowed me to find the two wires I needed.
    Those being the black/green and the black.
    Obviously, linking the two new bulbs in series would dim them down too much, so I wired them in parallel, that meant having to run double the amount of wire, but no big pain really.
    Wire used was standard speaker wire.
    The opening for the rear interior light is close to the rear trim, four screws removed from said trim and pulled down off it's press stud fixings and it drops away.
    Wire routed from the light opening behind the rear of the headlining to the passenger side, tucked in behind the rooflining trim and off towards to the front of the car. Once at the A pillar, the wiring is passed through the headlining trim to the felt inner door seal and behind this all the way down the A pillar and by the side of the dash. Then it's passed through into the space above the trim behind the glovebox.
    I chose to use the passenger for both runs of wire because on the drivers side A pillar I have wiring coming up for the auto dim rear view mirror and also wiring for the microphone for the bluetooth handsfree integrated into the Becker headunit.
    Both lights aren't Audi (shock horror) they are footwell lights from an MGF of all things. I was going to order Audi version from the A6 or A8, but a chance quick search of EBAY for "footwell lights" brought these up. Bid, got them for 99p, but was ripped on the postage of £5. Anyway, they came in the trims used in the MGF, (REALLY crappy plastic I might add) but the lights themselves are neat little units.
    I used the trims they came with to mark out the hole in the trim where I wanted the lights.
    Now for something totally unexpected, the tray under the parcel shelf already had a hole in it, "exactly" the right size , just next to the little removable hatch my model has to gain access to an airbag connector.
    So only needed to cut a hole in the trim panel behind the glovebox.
    I'll let the pictures explain the rest. Will try and nab a couple later when it's dark.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
  • Jas11n
    • 5067
    • BRY
      • 3755
      Didn't you fancy HIDs?
      Nice Work
      • gavs20v
        • Sep 2004
        • 3057
        Tims old green avant had factory fit footwell lights jas. Not seen them before.
        S2 Cabriolet.........
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Nice one Jas. It's the sort of thing you miss when you're used to other cars with these.
          I'd like to put some lights in the bottom of the doors, as now I'm used to the A3 and it's nice to see what you're stepping out on to at night.
          SS
          • s2driveruk
            • 12696
            yeah thats looking good, just need a couple of red leds in the front unit to do the cockpit light at night with the instruments a la A6, really love that and wil install on the S2 at some point
            1992 3b S2 Coupe
            • Jas11n
              • 5067
              Really tried, but couldn't get them for a 38mm festoon
              Seem to remember someone had them, but couldn't remember who. Can now
              Yeah, have thought about that. Might order a light fiber strip from an A8 and see what that all about :mischeif:
              Shame the passenger side one is just say visible, but it's just not possible for it to go under any further. No room.
              • Keeper of The Kitten
                • Dec 2003
                • 2317
                Clever!
                Maybe a lick of black paint on the edge of the lamp diffuser that faces towards the seat would help to hide it?
                Martin Cutting
                • Jas11n
                  • 5067
                  Originally posted by Keeper of The Kitten
                  Clever!
                  Good idea, will give that a go tomorrow
                  • pastures16
                    • 2058
                    liking that new instail mate whats with the gearnob and who is that bloke GAV not seen him for ages
                    94 s2 avant
                    aoc member 1116
                    • Jas11n
                      • 5067
                      S6 (B5)
                      Saves the original from wear and tear
                      • andyg plym
                        • Nov 2006
                        • 4646
                        yes,i was just gunna say ive got these in my avant....funny thing that seeing as it IS Tims old avant
                        • Skull
                          • 3506
                          • Country: Slovenia
                          anyone has a clue what is this panel in the middle of the pic? it is removable. I thought some light could be fit at its place, but didt look at etka.
                          Audi Quattro WR
                          • Jas11n
                            • 5067
                            It is removable, behind it is a connector for the drivers airbag.
                            • pastures16
                              • 2058
                              any pics of these andy
                              94 s2 avant
                              aoc member 1116
