There is a lot of wiring/gremlins to sort out.
Looks like the brake reservoir sensor plugs have been chopped, there is a bypass link in one of the bulkhead connectors.
The fuel pump is running with the ignition on and when you remove the fuel pump relay it still runs?
Battery main cable runs from the boot down the nearside and right round the front of the car so would like change that and run through the chassis leg.
Think the original ABY loom fuses have been spliced in to the v6 loom under the glove box instead of feeding to the fuse box.
