95 S2 Limo Replica
  • sjw185
    • 1175
    Work on rear differential.
    Found a old allen key in my tool box from about 25 years ago when working on my Jetta syncro.
    Removed plugs and drained oil.
    Fitted new seals and filled with fresh oil.
    • sjw185
      • 1175
      Went with the street hardness set up from Verkline.
      Made up new rear brake line for subframe, repainted heat shields and tank straps.
      Refitted subframe on its own first.
      • larsaskogstad
        • May 2020
        • 674
        • Country: Norway
        #63
        Looking good
        "street hardness set up from Verkline." do you know how these compares to the track hardness?
        Is the street hardness a step up from original bushings or quite similar?
        https://www.s2forum.com/forum/member...-3b-1991-coupe
        • sjw185
          • 1175
          Think red poly is supposed to be similar to original but probably less forgiving on the bumps that rubber.
          What it will be like to drive only time will tell? looking forward to feeling the B4 rear all refreshed
          Verkline street is 75ShA and track is 85ShA
            • Dec 2017
            • 5992
            I have Alberts red bushes and they are fairly soft but slightly harder than oe. Spot on for road use.
            • sjw185
              • 1175
              Sounds good, Using your Nothelle thread for reference
                • Dec 2017
                • 5992
                Nice. Glad you found it of use
                • sjw185
                  • 1175
                  Continued fitting wishbones and rear differential.
                  Painted rear calipers and ordered rear HEL lines.
                  Unfortunately I ordered the wrong female end but made it work with a washer and a longer male fitting against the spring clip.
                    • Dec 2017
                    • 5992
                    Looks like a nice S2 lurking in the background?
                    • sjw185
                      • 1175
                      Originally posted by sjw185
                      Tried the hoover with a wee hose but I think ive already got all the loose stuff out and I am left with the a few crushed bits that wont shift.
                      Resorted to brute force and swearing loudly but no joy.
                      After all the fighting trying to unlatch the rear seats they just opened all on there own
                      The release oil must have worked its magic.
                      The bigger side needed some additional work as I bent the level when trying to force it with the spanner.
                      It was unlocking but the latch was not clearing the fixed pin.
                      Once I figured that out and bent the bar back its unlocking again.
                      • sjw185
                        • 1175
                        Yea belongs to forum member as2q helping him get it ready for MOT after a few years in storage
                        • quattroamm
                          • Dec 2003
                          • 306
                          Any more updates
                          1991 90 quattro 20v sport 450 bhp
                          Rs2 engined ur quattro sold
                          11 golf tdi
                          • sjw185
                            • 1175
                            Yea got some more stuff done.
                            Finished up rear subframe and connected handbrake cables.
                            Removed intercooler setup to fit original crossmember and ABY intercooler.
                            Mixed and matched old boost hoses to get me going.
                            Fitted a flexible joint and a 76mm cat to the exhaust.
                            Not managed to upload any photos to the forum for some reason?
                            • sjw185
                              • 1175
                              Before
                              After
                              • sjw185
                                • 1175
                                Fitting S2 snub mount and removing V6 item from below
                                Old 3b hose
