My Quattro
  • sal_s2
    • 1287
    So, I finally received the correct front bearings ( on the third attempt). Pressed them in and fitted the front struts and brakes
    • sal_s2
      • 1287
      I think I'm going to need some strut top bearings though.
      Is it true that the blue ones are better than the greens?
      I don't want the solid ones as they didn't last that long on my s2
      • quattrostyle
        • Oct 2006
        • 6229
        Which ones didn't last, compbrake?
        You may want to try Albert's (offset) top mounts?
        • sal_s2
          • 1287
          Mine were the standard blue ones
          • quattrostyle
            • Oct 2006
            • 6229
            So you did not try solid topmounts like Compbrake or the likes yet?
            • sal_s2
              • 1287
              I tried them on my s2, one side started knocking within a few months
              • quattrostyle
                • Oct 2006
                • 6229
                Hmm, maybe Albert's mounts last longer? Well hopefully.
                Stock top mounts will be gone in no time with coilovers or any lowering suspension for that matter.
                • sal_s2
                  • 1287
                  Time for a little update, proof that I managed to get it on the road for all the doubters, you know who you are
                  This gallery has 4 photos.
                  • sal_s2
                    • 1287
                    Thing is, I'll be pulling the engine out at some point as the clutch has started to judder, so I'll switch the flywheel out for a heavier one at the same time. Swap the braking system for a dual vac servo from Alex and sort out some of the wiring so might be another 5 years until the next update, stay tuned
                    • robo
                      • Aug 2004
                      • 2086
                      • Home: Poland Current: England
                      #145
                      [QUOTE=sal_s2; I'll be pulling the engine out at some point as the clutch has started to judder,[/QUOTE]
                      We had to do this twice on my UR.
                      sigpic_________
                      Rob
                      • Jaswan
                        • Apr 2011
                        • 765
                        #146
                        Looks Amazing!!
                        (thanks for the fuel tank btw)
                        Jase.
                        • GT500
                          • Jun 2006
                          • 2181
                          Just take the box out.
                          Rob..
                          87 UR 20v ABY
                          97 S6 Avant
                          • sal_s2
                            • 1287
                            Originally posted by Jaswan
                            Looks Amazing!!
                            Jase.
                            No probs
                            • sal_s2
                              • 1287
                              I'm building another engine anyway that I'm going to fit instead. Also need to lower then engine a touch as the wagner inlet manifold hits the bonnet. It'll be easier to fit the shortened engine loom properly with the engine out the way. I routed it incorrectly resulting in some of the auxilary loom wires catching on the steering arms. I fitted a double head gasket to drop compression more when I had the gt35 turbo fitted which I no longer want in place,
                              Prob a couple more reaons to pull the whole lot out but cant think of them right now Maybe fit a different turbo! Anyone got an rs2 turbo lying around ?
                                Looks fantastic sal_s2
