My volcano RS2 Avant
agree on the EGTs, disagree on the faster spool up and throttle responce.
the wider the runners, the more lag you will get, as the velocity of gasses going through the turbo is smaller.
off boost, i dont know,but in regards to spool and lag, everything else being equal, the wider runners will create a bit more lag.
Whether that is noticable, i dont know. i havent done any test on that.Comment
Indeed. Velocity and flow are always a tradeoff.Comment
Mapped this.
Best FATS 3.3 sec with 3 people + luggage in car.Last edited by prj; 3 December 2011, 15:37.Comment
Just realized that FATS was probably downhill
Most of the mapping was done on non level terrain, so FATS varies from 4.3 to 3.3.Comment
just post a log through with time vs rpm so we can plug it in the virtual dyno! Best i have measured after tweaks was 2.8 and most play around 3secs but im not sure i can get a proper FATS measure from vems logs.
good numbers, but why do you always have 3 people in the car? Who is the 3d guy all the time? Same thing with Ross! Are you worried that the car will fly??? Dont ! its just a K27/26! not a jet engine! hahaLast edited by A80Avant; 3 December 2011, 17:15.Comment
The key is oem narrows below optimum flow point which becomes a bottleneck causing a loss in flow bit like a kink in a hose pipeagree on the EGTs, disagree on the faster spool up and throttle responce.
Well this is slower than Ross' setup. Has about 1.8 bar peak boost, otherwise IAT's climb.
And the log times are useless as are FATS times because we did downhill and uphill pulls.
So you will have hp variations of 100 hp just from that...Comment
LWB Audi Sport Quattro projectComment
Avantus has H-rods, but IAT's started climbing and the compression ratio was stock with the head skimmed.
I think the car would not make a lot more power at 1.9 or 2 bar compared to 1.8, because I would have to pull at least 3 deg timing to get there.
Also his WG spring did not really allow more boost. N75 is pretty much maxed as is 75-90% most of the time.
The car feels very nice though, good cold start and warmup, etc...
I am pretty positive it has at least 400hp and Steve seemed happy with it.Comment
people with fear with the torque
