My volcano RS2 Avant
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    #166
    Out of interest... I see that almost every RS2 project with different turbo has a 3" downpipe. Mine still has stock RS2 DP and it's even a bit dented up on the bottom. So I'm wondering if it would gain in spool (and perhaps top end) with a 3" one to join my already 3" decat exhaust, of if it's isn't a bottleneck at all?
    Oh and 5th gear on a cool motorway from our way back home
    It underreads a bit we found out, so that's pretty much 2bar.
    • A80Avant
      • 10873
      • Country: Greece
      #167
      3 inch downpipe will have some good effect on EGTs but i wouldnt expect a huge difference in spool
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #168
        i have the same Boost gauge as you mate¡¡ 2.5Bar just in case eh?
        • A80Avant
          • 10873
          • Country: Greece
          #169
          no, that boost gauge is how it comes like this. Everyone has the 2.5bar.
          • prj
            • Mar 2010
            • 6308
            I would not bother with a 3" DP/Exhaust with a K26 #6 hotside.
            • Avantus
              • Sep 2007
              • 941
              • Country: Belgium
              #171
              Ok thanks for the input. Might do it in the spring, also to have a flexi part at the end of the downpipe then, to spare the turbo/manifold a bit.
              100-200 real GPS km/h starting in 4th gear is around 10.3sec. In 3rd/4th down to 9.5sec. With me alone that is.
              • A80Avant
                • 10873
                • Country: Greece
                #172
                3d/4th is always faster.
                sounds like my old 3071R times, although i have to go back and look at the PB runs way in the past to get a proper time.. will look later on
                • Avantus
                  • Sep 2007
                  • 941
                  • Country: Belgium
                  #173
                  Nice
                  Imagine having a DSG gearbox in these things... that would be FAST
                  • EspenW
                    • Apr 2007
                    • 1534
                    • Country: Norway
                    #174
                    Not quite... many turbo cars are faster using 4th only. The 3rd to 4th shift not only takes time in itself, but regaining boost takes a good while too.
                    I'm 0.3s faster 100-150kmh using 3rd vs 4th (2.68s vs. 2.99s), but 100-200 I'm considerably faster using 4th only as shift time and time off boost wastes much more than 0.3s. It all depends on the power/torque curve. However, peaky turbo or NA cars will often be faster using 3/4th as there is not enough power available at 100km/h in 4th (approx 3500rpm in our cars)
                    DSG would be fantastic though. A match made in heaven for turbocharged cars.
                    1994 80E Avant
                    1986 2L Golf 2 on Alcohol
                    • Ross
                      • Aug 2005
                      • 3399
                      Some awesome results here, would have loved to have seen how it goes myself - I have a bit of an addiction to midnight mapping sessions now
                      Obviously 3rd/4th debate is going to depend on where your turbo kicks in and how much torque it produces. I must admit, mine is great in 4th at 3500rpm because by 3800rpm I'm seeing 2.2bar, would be interesting to get some times and compare (i know I keep saying that!) Are you using a K26/7 hybrid similar to mine?
                      • prj
                        • Mar 2010
                        • 6308
                        If you had flatshift in your Motronic, that would not be a problem.
                        • Avantus
                          • Sep 2007
                          • 941
                          • Country: Belgium
                          #177
                          @Ross: It's one of Richards latest K26/27's, so I suppose it's the same as yours?
                          No headwork at mine though, so def. no 450-460hp like yours.
                          Next problem popped up unfortunately. My PAS is perfect when cold,
                          but when warm it fails to give assistance when parking, with a juddering steering wheel. No noises from the pump, but it's started leaking. Oil is new, so that won't be a cure. At first it was only when turning right, but on warm standstil both directions. Just hope it's the pump and not the rack.
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #178
                            Probably pump, but check the belt is tight
                            sent using Android
                            • Avantus
                              • Sep 2007
                              • 941
                              • Country: Belgium
                              #179
                              yes tension on the belt is perfect. The pump has had it's periods of groaning and making a slight metallic knocking with your ear next to it on idle. Was better the last half year, but probably for the bin now
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #180
                                Don't throw it away. A shop here in the UK can rebuild it with guaranty
                                sent using Android
                                here is a link:
                                Steering racks for cars, rally cars, light commercial vehicles, and everyday cars, either new or rebuilt, huge experience telephone for more information 0121 772 8000
                                had a rack rebuilt and a pump checked, and Lloyd had his pump rebuild in record time.
