Originally posted by rynaqui
View Post
Disappointed with my single mass flywheel and uprated clutch. oem set up feels much nicer on my urS6. That is why I say the above.
Re the oem crank seal, I thought I read on here somewhere a while ago that the oem was not great, and that a genuine brand one might be better. Could be just my imagination.
One of the things that might be causing the disappointment regarding my clutch set us is that a bit of oil might be leaking out of my new oem crank seal.
My first gear is noisy now, so will eventually be swopping out my box so I'll be able to see what's going on.
Just my tuppence, so that you can consider it and make your own choices.
As the car is so perfect, are you not going to get a second hand front cross-member to replace the dented one, or is it not impeding the air flow ?
Kind regards.
