Bottom End Rebuild Pics
This is a sticky topic.
  • Mark Halligan
    • 2001
    Crank and girdle installed, the girdle has silicon flange sealant between it and the block pan rail.
    Mark - Modded
    • Mark Halligan
      • 2001
      Mark - Modded
      • Mark Halligan
        • 2001
        Mark - Modded
        • Jon441cc
          • Dec 2005
          • 2061
          Very nice Mark Am i right in thinking that the lightened crank and Gurdle are there because the motor will be high reving.
          Nice mod on the water port also
          • Mark Halligan
            • 2001
            All in
            Mark - Modded
            • Audilard
              • Oct 2003
              • 87
              Looks great Mark!
              Darin
              1989 Audi 80tq
              • Mark Halligan
                • 2001
                All bolted in and torqued up.
                Mark - Modded
                • Mark Halligan
                  • 2001
                  Just trying to build a robust bottom end, would have been better if I had stepped up in wrist pin size like I said earlier, but having said that I know of a few powerful motors that have used the 20mm pin ok.
                  Mark - Modded
                  • Mark Halligan
                    • 2001
                    Windage tray needed some modding to fit around the studs
                    Mark - Modded
                    • Jon441cc
                      • Dec 2005
                      • 2061
                      Mark is this a 7A block ?
                      • Ross
                        • Aug 2005
                        • 3399
                        NICE!! I've been searching for some rebuild pics... that's one mean engine. I wish I had some pics of mine! Keep 'em coming Is this enigne complete now? How are you running in the engine?
                        • Mark Halligan
                          • 2001
                          10mm spacer was used between oil pump and pick up pipe (girdle is 10mm thick). I used a 7A pick up pipe with two paper gaskets (ABY/ADU pick up uses an O ring).
                          Mark - Modded
                          • Mark Halligan
                            • 2001
                            Nope its an ABY, the one my car was born with
                            Mark - Modded
                            • Jon441cc
                              • Dec 2005
                              • 2061
                              Originally posted by Mark Halligan
                              Spacer was 10mm spacer was used between oil pump and pick up pipe (girdle is 10mm thick). I used a 7A pick up pipe with two paper gaskets (ABY/ADU uses an O ring).
                              i was just about to comment on this ... looks like you've though of everything
                              • Mark Halligan
                                • 2001
                                Its running now, done only 750miles, so far, so good
                                Mark - Modded
