Originally posted by piotr
View Post
Audi RS2 -94 Swe
Engine is looking fantastic but did you inspected the DMF ?Not 100%sure from the picture but the surface looks like its burn .
Originally posted by SteveH View PostNice bike! I see you're into cycling too Great build, hope you can film the first startup for us
- 1 like
Today i got some flywheel bolts from the Audi dealer. Quick home to the garage to start install the engine. Mounted my reinforced Sachs clutch kit and new throw out bearing.
Intake and all other stuff that was "in the way" was removed. Installation was a little tricky but went well, maybe 20min.
Bolt for flywheel, 1st 30Nm 2nd 90 degres according to manual:
Bolts for pressure plate 25Nm according to manual:
Engine installed:
Can somebody please tell me if this bolt/nut is for tensioning the AC belt? If i use this bolt to tension the belt it will apply pressure to the engine block to tension the belt/bracket, maybe it's right? I can't find anywhere..
Tomorrow i will order/pickup stainless hose clamps as i didn't have for all coolant water hoses and pressure hoses. Then i will continue to assemble the engine.Last edited by s0_big; 18 June 2019, 23:00.
- 3 likes
Today i thought it was the big moment when i was going to install the engine in the car. Up early and to the garage only to find out that i didn't find the bolts to the flywheel...
I have papers that i bought new ones but can't remember if i got them or not, anyway i can't find them. So that was a huge dissapointment today. I have order new ones today but i will have to wait a couple of days before they arrive. I managed to mount my turbo today, thought it was easier with the engine out of the car.
45764-e20efe03326d6694df95b39c0a240f22.jpg45764-47028b1b6bb2c4a293a47db17d5dc15a.jpg45764-afdfb1e9e5078dee619371463a36b84b.jpg
- 1 like
More new parts! Found this AKG cooler (Audi original). My other cooler was not that good.
Engine get closer to it's home every day now.. maybe on sunday it Will find Home
20190611_232456.jpgLast edited by s0_big; 12 June 2019, 21:49.
- 3 likes
Some goodies arrived today!
Brand new KKK 24 7200 - "RS2 turbo"
Mr cat inspector checks the parcel:
45764-98cc22645cac98b5fcdcd3f10eea7ce4.jpg45764-170e86ba4c3ccee1c08d7e8ab4898468.jpg45764-0c999e88c7fdf13b43ede17938b1d6d4.jpg45764-5061a8fbe7532428c9447c4125199a8e.jpg
Hopfully it works like it looks!
- 2 likes
Injectors and fuelrail cleaned and painted, ready to work!
Test fitted on the intake:
Clips for injectors and some other stuff will be leaved for galvanizing tomorrow.
Also had time to assemble the oil cooler with air duct. The IC also got some attention, ready to mount with new O-ring
45764-80151fb0ed4d756c216a4a33b00931be.jpgLast edited by s0_big; 9 June 2019, 18:03.
- 3 likes
Workday! Today i Sourted out most of the crank case ventilation. Painted pipes and washed original hoses, fitted with stainless clamps of different kindes. Lots of cleaning but well worth it. Always takes time to sort out. Changed the steering rack dust cover that was broken. Lots of other small things mounted to the engine. Its really starts to feel like its going the right way now! Some more parts will be sendt to galvanizing, like pressure transducer and some more bolts i found. The fuelrail and injectors needs some fresh paint and cleaning aswell, maybe have time to paint tomorrow..
Turbo arriving hopfully tomorrow or Monday. Maybe next week or next weekend the engine will find home to the car again =) Also put an order on the little extra watercooler, Audi original one
Some pictures of the engine after todays work:
Close up on the small stainless clamps:
45764-7fb977c7e8a8244c746e1e2ce9199188.jpg45764-f88526d5bfdb1d3138ff79f8e1d86e70.jpg45764-6ec46f45a205952639d1e82e3fa94195.jpg45764-11910efad3da1b540271c27808bc6a0c.jpg45764-7572ae9d19692faa48916b64d9727331.jpg
- 1 like
