Mrc600
This is a sticky topic.
  • audiman
    • 4827
    Other downside to heat wrapping is it is highly flammable if it gets oil on it. A small oil leak from say RC gasket or something could end a disaster. I would go for ceramic coating, but thats an expensive process and for the gains, not sure if its worth it?
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
      Yeh I've seen vids on the net of that happening.
      Ceraminc coating is about 150 my downpipe has been coated by Graham and Tekkno in Belzona and then had wrap on top.
      The EM and turbo hotside have also been ceramic coated inside and out
      • alg
        • Apr 2004
        • 1160
        #108
        I was always told to avoid wrapping due to the danger of a melted exhaust ?!!
        Alastair
        RS2
        • audiman
          • 4827
          not sure about melting, but mild steel degrades quicker and normally drop apart after about 2-3 years. Stainless (and i mean 316 and above) wont melt and it wont rot.
          Audi UR Quattro
          • martinjs
            • 3205
            C'mon Doug, spill the beans. Is it up and running yet?
            • Doug_RS2
              • 3847
              #111
              not yet - not had time to do anything - all teh fab work is done, just got oil, water and ps lines to stick in, then wiring, fuel rail, and throttle cable to sort out then it should be ready to fire - I hope
              • Doug_RS2
                • 3847
                #112
                this is how far I have got
                • Doug_RS2
                  • 3847
                  #113
                  another
                  • audiman
                    • 4827
                    Looking good mate Wish I had some time to come up and help you out, but i have my own work projects to get done.
                    Audi UR Quattro
                    • dan_b
                      • Sep 2003
                      • 3670
                      #115
                      Just a thought - if your WG exhaust is dumping all its hot air infront of your front wheel, isn't that going to cause issues with overheating the brake setup on that side?
                      Damned impressive work, can't wait to hear it from West London when you fire it up in Banbury!
                        Looking good so far doug, what are the 3 downpipe taps for?
                        Tom, How is the golf coming along?
                        • Doug_RS2
                          • 3847
                          #117
                          the WG exhaust is plumbed into the downpipe for now.
                          the 3 taps on the DP are for EGT(with an adapter), wideband lambda and the stock lambda
                            Ah was the 3rd one I couldnt work out
                            • dan_b
                              • Sep 2003
                              • 3670
                              #119
                              Just wondering why do you need two lambdas ? Was wondering also why you need two recirc valves?
                              • martinjs
                                • 3205
                                I think its a safety measure when running high boost, 2bar+ i presume with Dougs car, incase one fails.
